Troubles uploading firmware to mutable instruments grids
baszor
Post by baszor » Mon Nov 04, 2019 5:32 pm
Hi guy's,
I've build a lot of st32 driven modules and was able to flash the chips with the st-link/v2 adapter.
Grids makes use of the mega328P chip and I try to use an arduino uno to flash.
I'm able to start the flashing process now after solving some USB access issues by Virtualbox running on OSX.
But i still get error's. Especially on the efuse flashing and in the end i get the error the programmer is not responding.
Does anybody have a clue what's going on here?
Or is only the bootloader and main part needed to pass? See the log below:
vagrant@vagrant-ubuntu-trusty-64:/vagrant/eurorack-modules$ sudo make -f grids/makefile bootstrap_all
make[1]: Entering directory `/vagrant/eurorack-modules'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/vagrant/eurorack-modules'
make -f grids/bootloader/makefile
make -f grids/bootloader/makefile fuses
/usr/local/CrossPack-AVR/bin/avrdude -V -p m328p -c arduino -P /dev/ttyACM0 -B 10 -e -u \
-U efuse:w:0x05:m \
-U hfuse:w:0xd8:m \
-U lfuse:w:0xff:m \
-U lock:w:0x2f:m
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f
avrdude: erasing chip
avrdude: reading input file "0x05"
avrdude: writing efuse (1 bytes):
Writing | | 0% 0.00s ***failed;
Writing | ################################################## | 100% 0.05s
avrdude: 1 bytes of efuse written
avrdude: reading input file "0xd8"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: reading input file "0xff"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.06s
avrdude: 1 bytes of lfuse written
avrdude: reading input file "0x2f"
avrdude: writing lock (1 bytes):
avrdude: 1 bytes of lock written
avrdude done. Thank you.
/usr/local/CrossPack-AVR/bin/avrdude -B 1 -V -p m328p -c arduino -P /dev/ttyACM0 \
-U flash:w:build/grids/grids.hex:i \
-U flash:w:build/grids_bootloader/grids_bootloader.hex:i \
-U lock:w:0x2f:m
Reading | ################################################## | 100% 0.00s
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: reading input file "build/grids/grids.hex"
avrdude: writing flash (12278 bytes):
Writing | ################################################## | 100% 2.36s
avrdude: 12278 bytes of flash written
avrdude: reading input file "build/grids_bootloader/grids_bootloader.hex"
avrdude: writing flash (31278 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: stk500_recv(): programmer is not responding
make: *** [bootstrap_all] Error 1
djthopa
Post by djthopa » Mon Nov 04, 2019 5:50 pm
Hope this helps, cant guarantee but i seem to remember doing this:
make -f grids/bootloader/makefile hex
make -f grids/makefile upload
make -f grids/makefile bake
make -f braids/makefile upload
baszor
Post by baszor » Mon Nov 04, 2019 6:30 pm
djthopa wrote:Hope this helps, cant guarantee but i seem to remember doing this:
thanks ... but that didn't help... :despair: especially the braids part :hihi:
djthopa
Post by djthopa » Mon Nov 04, 2019 6:40 pm
Oh shite!
I do recall the bake bit!
Good luck :tu:
baszor
Post by baszor » Mon Nov 04, 2019 7:23 pm
If you take a look at the log, the fuses are written at the 2nd try, the grids.hex passes, but the writing of the bootloader.hex passes/fails? Also the lock bits are not written....
col
Post by col » Mon Nov 04, 2019 8:43 pm
My notes on flashing a uGrids via Vagrant:
avrdude -V -p atmega328p -c usbasp -P usb -B 10 -e -u -U efuse:w:0x0f:m -U hfuse:w:0xd8:m -U lfuse:w:0xff:m -U lock:w:0x2f:m
avrdude -V -p atmega328p -c usbasp -P usb -B 10 -U flash:w:grids.hex
Altitude909
Post by Altitude909 » Mon Nov 04, 2019 9:09 pm
I'd say the device your flashing with is causing the issues. The codes running, but the programmer is hanging up
col
Post by col » Mon Nov 04, 2019 9:56 pm
what comes up if you run lsusb ?
It should list the programing device then you can run the commands directly and see whats going on.
baszor
Post by baszor » Tue Nov 05, 2019 9:29 am
col wrote:what comes up if you run lsusb ?
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 2341:0001 Arduino SA Uno (CDC ACM)
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
and when I run dmesg i get:
[ 48.879325] usb 2-1: new full-speed USB device number 2 using ohci-pci
[ 49.187287] usb 2-1: New USB device found, idVendor=2341, idProduct=0001
[ 49.187300] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[ 49.187310] usb 2-1: Product: Arduino Uno
[ 49.187320] usb 2-1: Manufacturer: Arduino (www.arduino.cc)
[ 49.187329] usb 2-1: SerialNumber: 6493534313335121A061
[ 49.196113] cdc_acm 2-1:1.0: ttyACM0: USB ACM device
[ 49.208786] usbcore: registered new interface driver cdc_acm
[ 49.208790] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
So I can program at /dev/ttyACM0?
[EDIT] "The weirdest thing is that if I remove some leads from the arduino to the grids board the same communication happens... maybe i'm communicating with the arduino instead of the grids boards :eek:
I just ordered a cheap USBavr programmer. Will continue when the thing has been delivered..."
baszor
Post by baszor » Wed Nov 06, 2019 9:51 am
col wrote:My notes on flashing a uGrids via Vagrant:
... how do i program the bootloader? with what command?
slo
Post by slo » Wed Nov 06, 2019 11:18 am
I had all kinds of trouble with my Uno’s, I was trying to use them as an ISP.
Finally I flashed Optiboot bootloader and then they worked.
http://www.gammon.com.au/bootloader
baszor
Post by baszor » Wed Nov 06, 2019 2:56 pm
Solved the issue in a VM with windows... after installing the arduino IDE there, flashing went perfect with avrdude (could even use the gui version avrdudess)
copied the hex files to windows, wrote them and the fuses. And off we were.
Thanks for the support!
col
Post by col » Wed Nov 06, 2019 3:02 pm
I don't think mine used one, I thought it was combined in the grids.hex. If your "make" generated one then you would use:
avrdude -V -p atmega328p -c usbasp -P usb -B 10 -U flash:w:grids_bootloader.hex
baszor
Post by baszor » Thu Nov 07, 2019 9:39 am
Ready to go! thanks for the help guy's!
PabloSrNaranja
Re: Troubles uploading firmware to mutable instruments grids
Post by PabloSrNaranja » Fri Jun 05, 2020 2:58 am
Hi! Did anyone have a Grids .hex bootloader? Will be apreciated.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Fri Jun 05, 2020 9:24 am
bootloader is not the same thing as firmware. maybe you are asking for the wrong thing?
batchas
Post by batchas » Sat Jun 06, 2020 1:16 am
FS: KESAKO Player & Reverb for Serge and Buchla
PabloSrNaranja
Post by PabloSrNaranja » Tue Jun 09, 2020 3:38 pm
Ohh, thanks so much! :yay:
PabloSrNaranja
Post by PabloSrNaranja » Sun Jun 28, 2020 12:33 pm
Hi, its possible. I assume that I need the grids.hex and the grids_bootloder.hex.
First I try to program the bootloader and I get this:
Can anyone guide me out? Thanks in advance
>>>: avrdude -u -c usbasp -p m328p -P COM1 -B 0.5 -U lfuse:w:0xff:m -U hfuse:w:0xd8:m -U efuse:w:0xff:m -U lock:w:0x2F:m -U flash:w:"\\192.168.1.67\home\Dropbox\DIY PROYECTOS\SMD2\1.- Grid\grids HEX\grids_bootloader-MI.hex":a
avrdude.exe: set SCK frequency to 1500000 Hz
avrdude.exe: AVR device initialized and ready to accept instructions
avrdude.exe: Device signature = 0x1e950f (probably m328p)
avrdude.exe: NOTE: "flash" memory has been specified, an erase cycle will be performed
avrdude.exe: erasing chip
avrdude.exe: reading input file "0xff"
avrdude.exe: writing lfuse (1 bytes):
avrdude.exe: 1 bytes of lfuse written
avrdude.exe: verifying lfuse memory against 0xff:
avrdude.exe: load data lfuse data from input file 0xff:
avrdude.exe: input file 0xff contains 1 bytes
avrdude.exe: reading on-chip lfuse data:
avrdude.exe: verifying ...
avrdude.exe: 1 bytes of lfuse verified
avrdude.exe: reading input file "0xd8"
avrdude.exe: writing hfuse (1 bytes):
avrdude.exe: 1 bytes of hfuse written
avrdude.exe: verifying hfuse memory against 0xd8:
avrdude.exe: load data hfuse data from input file 0xd8:
avrdude.exe: input file 0xd8 contains 1 bytes
avrdude.exe: reading on-chip hfuse data:
avrdude.exe: 1 bytes of hfuse verified
avrdude.exe: writing efuse (1 bytes):
avrdude.exe: 1 bytes of efuse written
avrdude.exe: verifying efuse memory against 0xff:
avrdude.exe: load data efuse data from input file 0xff:
avrdude.exe: reading on-chip efuse data:
avrdude.exe: 1 bytes of efuse verified
avrdude.exe: reading input file "0x2F"
avrdude.exe: writing lock (1 bytes):
Writing | ***failed;
################################################## | 100% 0.04s
avrdude.exe: 1 bytes of lock written
avrdude.exe: verifying lock memory against 0x2F:
avrdude.exe: load data lock data from input file 0x2F:
avrdude.exe: input file 0x2F contains 1 bytes
avrdude.exe: reading on-chip lock data:
avrdude.exe: verification error, first mismatch at byte 0x0000
0xef != 0x2f
avrdude.exe: verification error; content mismatch
avrdude.exe done. Thank you.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Sun Jun 28, 2020 3:44 pm
PabloSrNaranja
Post by PabloSrNaranja » Mon Jun 29, 2020 6:17 am
This is why
https://forum.arduino.cc/index.php?topic=535617.0
Thanks for the answer! I use USBASP but no USBtiny or Arduino. Still applyes?
After including i get this:
>>>: avrdude
grids_bootloader-MI.hex: 2.606 / 32.768 Bytes (7,95%)
Reading | ################################################## | 100% -0.00s
Writing | ################################################## | 100% 0.02s
################################################## | 100% 0.09s
0xef != 0x2f
Thanks!!
EATyourGUITAR
has no life
Post by EATyourGUITAR » Mon Jun 29, 2020 6:55 am
this thread is about programming the grids firmware using an arduino uno. please post a link or a picture so I can see what hardware you have for programming.
for example, the command line for AVRDUDE will have different options depending if you used this
https://www.microchip.com/DevelopmentTo ... /ATAVRISP2
or this
https://www.arduino.cc/en/Main/arduinoBoardDuemilanove
or this
https://store.arduino.cc/usa/arduino-uno-smd-rev3
I don't know what you are using so I can't say if it is correct.
PabloSrNaranja
Post by PabloSrNaranja » Mon Jun 29, 2020 1:36 pm
ok, sorry for the confusion. I´m trying to use an USBASP device like the one in the photo, more info is here: https://www.fischl.de/usbasp/
Thanks in advance.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Mon Jun 29, 2020 2:48 pm
Ok I think I know what it is now. Usbasp is ok. The problem is that you can not set some fuses (lock bits) without first doing a chip erase. There is a possibility that the lock bit will write but not report the status correctly. I think this must be more rare. Start with a chip erase command in AVRDUDE. Take the build script apart. You do not need to write the locks bits every time you flash. That will generate more errors. Feed the commands in one at a time. Make sure you are flashing the bootloader. AVRdude must be 5.2 or newer.
See here
https://www.avrfreaks.net/forum/avrdude ... -lock-bits
PabloSrNaranja
Post by PabloSrNaranja » Tue Jun 30, 2020 3:56 am
See here
Now it uploads, except for the lock bit, it works but not the first channel, also the clock is slow. I will test with patience.
Thanks a lot I will get back if I cant make it work :yay:
