Anyone have an idealtek PCSA PCB holder and can answer a ?
xonetacular
Post by xonetacular » Sat Nov 09, 2019 4:03 pm
Can you confirm if the max working height of the pcsa-1 and pcsa 2 is really only 220mm (8.7") or two 104mm boards with the center piece as the data sheet says? it looks a lot bigger than that in all vids/pics I see. The pcsa-4 looks huge yet is only listed as 350mm high work space (13.8") but the pcsa-2 would be perfect if it fit a little bigger than advertised. I want to be able to fit two 5" high boards on top of each other.
if you have one of these (any model) and can measure the actual usable vertical space/post a pic with a ruler that would be a big help
Rowan
Post by Rowan » Sun Nov 10, 2019 11:45 am
I have a PCSA-2 and can confirm that the working board height is 220mm, as the rails are spring loaded you could actually squeeze a board that’s 230mm in.
xonetacular
Post by xonetacular » Sun Nov 10, 2019 2:31 pm
Awesome, thank you for that! ok so a little bigger but not much. guess I need the big MFer unfortunately.
Graham Hinton
Re: Anyone have an idealtek PCSA PCB holder and can answer a
Post by Graham Hinton » Sun Nov 10, 2019 3:03 pm
xonetacular wrote:Can you confirm if the max working height of the pcsa-1 and pcsa 2 is really only 220mm (8.7") or two 104mm boards with the center piece as the data sheet says?
The data sheet is wrong. I have a PCSA-2 and with the rails at their extreme positions you can get a 240mm board in easily, 245mm if you don't have the rails fully released. Turn the rails so that all knurled brass locks are towards the centre. Still not big enough for 2x 5" though.
xonetacular
Post by xonetacular » Sun Nov 10, 2019 3:11 pm
The data sheet is wrong. I have a PCSA-2 and with the rails at their extreme positions you can get a 240mm board in easily, 245mm if you don't have the rails fully back.
Ok thank you, my intuition was right then. What is the biggest you can fit on top and bottom in the 2 row config with the center rail in?
Graham Hinton
Post by Graham Hinton » Sun Nov 10, 2019 3:19 pm
xonetacular wrote:What is the biggest you can fit on top and bottom in the 2 row config with the center rail in?
120mm or 4.75" absolute maximum with the brass locks inwards.
xonetacular
Post by xonetacular » Sun Nov 10, 2019 4:41 pm
thank you. might just have to go for the pcsa-4 and maybe get a pcsa-1 later if it is too unwieldy for smaller stuff
