Live performance tutorial - Steevio
Live patching, designs, and techniques that push the performance envelope.
Steevio
Post by Steevio » Sun Nov 10, 2019 4:48 am
After publishing an improvisation called Steevio Live Improv 28-10-19 here a few days ago
I decided to explain my technique for note sequencing on my newly re-built rig. There's a brief intro then I continue on from where I left off after the above improvisation with a 5 minute rough jam, morphing the tune into something else on the fly, and then go into a detailed explanation for the last 10 minutes.
Aaronautical001
Post by Aaronautical001 » Sat Nov 16, 2019 6:33 am
:yay:
For my money, some of the most interesting videos on the inter web. Thanks for posting Steevio :hail:
Lots to think about.
BlueWolfSe7en
Post by BlueWolfSe7en » Mon Nov 25, 2019 7:30 pm
Excellent Steevio, really well thought out system & great explanation, mucho appreciation for taking the time to put this together :yay:
Strange Beautiful Machines
waves_of_awesome
Re: Live performance tutorial - Steevio
Post by waves_of_awesome » Sun Feb 09, 2020 2:07 pm
Thanks steevio, always look forward to your videos. Looks like the switch mix is a much more intuitive method than using switched multiples for routing. I'm curious, how often do you change the routing around during a typical set?
pmboos
Post by pmboos » Thu Mar 12, 2020 5:35 pm
I'm interested in this as well Steevio.
I first though want to thank you for taking the time do such an explainer video. I just am starting on my modular journey. I've been goofing off with semi-modulars quite a bit and this 1) shows me a lot more to think about (envelopes changing sequences!) and 2) tells me that my first steps of mostly getting utilities for processing my semi-modulars is probably the right choice (as opposed to getting more oscillators). For example, I have thought of that same 4MS QCD to effect clocks and also chose Branches for some randomization of what gets fired within a rhythm. I started with a Nifty Bundle as my skiff (for what its worth) and have 2 SQ-1s, and Orb, and a Crazy8 for sequencing.
One more compliment before I go onto asking a few additional questions... I love the sort of afro-latin vibe you are getting. I mean it is very distinctive and sounds great!
So first question, is that a vibe you go for..? If you don't do that vibe always, what considerations do you make when you want to change vibes?
In this set you didn't change tempo. What is the primary way you think of changing tempo. My mind goes in two directions, one is changing a master clock, but I can also think of making a multiplication or division of a clock become more predominant as well which would make something drastically faster or slower, but come from out of the background...
What types of non-sequence changes do you find yourself doing? It sounds like they are less predominant than sequence changes. I know with my semi-modulars, I find myself adjusting filters, attacks, LFOs, and decays the most. (I vary the sequences mostly be turning on and off played notes in the SQ-1s.) So I am interested in what you do with the non-sequenced stuff.
Thanks again for sharing this (and any answers to above in advance)!
Paul
“What actions can be taken to create a joyful, inspiring, and productive work environment?"
Steevio
Post by Steevio » Sat Mar 28, 2020 8:31 am
Hi sorry it took me so long to reply, I havent been on here for a while, just too busy..
I change the routings constantly, this particular video I'm not doing much with it, due to not wanting to have too much going on to confuse things, but normally I'll change the routings 5 or 6 times per tune, so in a 90 minutes set probably over 100 changes.
I just experiment, so sometimes a routing might not work, but its real easy just to unroute it, and try something else, so as long as you dont do anything too radical, its quite easy to keep it all under control, just slight alterations and flavours.
I hope that helps!
Steevio
Post by Steevio » Sat Mar 28, 2020 9:01 am
Paul
Hi Paul, sorry for taking so long to respond...
I answered the other question from waves_of_awesome in my response to them.
1/ thanks for the kind words, I dont really go for a vibe, I kind of work mathematically and choose the maths for the mood I'm in, so I might work in a certain minor key if I'm feeling that way, but I wont stick rigidly to it, I'll experiment around it and if something jumps out at me as fresh sounding I'll go with that for a while.. I dont like to stick to the obvious western scales, I quite often work microtonally (not in this video) I love using 3 limit and 5 limit just intonation, and as far as rhythms are concerned, I've always used polymeters and polyrhythms since i started as the main basis for everything I do, so thats where the Afro-Latin thing comes from, as polyrhythms are the backbone of all that music, so again its mathematical.
2/ I quite often work at one tempo for a while and then use master clock to change it, but if you're working in polymeters /rhythms, just by emphasising one of the polymeters over the others for your main pulse, then you are effectively changing the tempo, if your kick drum is in 5 step the tune will sound slower then the clock suggests etc.. which is similar to what you're saying..
3/ I do everything, I only emphasised the sequence changing for this video as that was what I was trying to show, but when I'm playing live, I do everything you are saying, but also I have digital modules like the Erbverb and Chimera which have multiple parameter change possibilities, and I generally control them from envelopes as I do with the sequences. It gives you so much control especially if you use a polarising offset generator to vary the amount and polarity of the envelope you're sending as well as the ADSR settings (The Erbeverb has that built in for some parameters), so I treat these type of modules as individual instruments. I dont use LFOs much, only for slight variations over time, I mostly use envelopes or looped envelopes if I want an LFO type effect but with more control over shape. I'm not much of a random guy, I like to be in control but with enough potential complexity to keep it constantly interesting and evolving.
I hope thats some help man!
pmboos
Post by pmboos » Sat Mar 28, 2020 12:02 pm
...snip...
No worries, asynchronous comms are what forums are about!
I appreciated that!
I super appreciate all of this... Between this and the video, I have a lot to mull over...
Thanks for taking the time to help others out!
electricanada
Post by electricanada » Sat Mar 28, 2020 1:52 pm
Thanks Steevio. I love your music, and I appreciate your incredible generosity in educating fellow musicians. You’re an inspiration on both.
Steevio
Post by Steevio » Sun Mar 29, 2020 1:39 pm
aww thanks for the kind words!
Jd1979
Post by Jd1979 » Mon Mar 30, 2020 10:30 pm
Thank you so much for posting this...I have been really curious about how to prepare for live performance and this video helped open up some doors for me.
jdaddyaz
Post by jdaddyaz » Wed Apr 08, 2020 10:43 am
I'm getting anxious thinking about one or two of the wires going kaput. What a headache that would be. Thanks for the videos Steevio!
Be good to yourself, and be good to others.
Waldemar
Post by Waldemar » Tue Aug 04, 2020 8:47 am
Man thats dope you are the craziest modulist i ever seen ;-)
When you open a teaching class for this?
I'm the first for registration.
All the best
Waldemar
Are you bored or do you want to do something active? Then follow us on our cycling route.
www.indre-waldemar.de/route
Rex Coil 7
Post by Rex Coil 7 » Tue Aug 04, 2020 9:19 am
Yea ... I'm hearing a little ethnic percussion .... but what really stands out are the electric piano-like tones and what sound like "jazz chords" (as people say these days). Every now and then there's a slight waft of 1970s live jazz/fusion performances .... and for whatever reasons Allman Bros/Gregg Allman (especially their live "jams") really stands out in parts of this. In fact, some of it is so much like that type of music that when the music in the video first started up my ears locked on to what (for all the world) sounded like the live version of "In Memory of Elizabeth Reed" ... I immediately thought "holy crap, is he really going to try to take that song on ... with a modular!!?!? .. by himself!?!?! ... I gotta hear this!!!". Something about the perceived chord changes combined with the tones that were used ... it just really caught me, like instantly. And then again several more times, throughout the performance.
Please know that was a compliment. :)
.. given the choice between conformity and self respect, I choose the latter.
.. dominion - noun: control or the exercise of control . power . possessed and controlled domain . sovereignty . having dominion over the world . supreme authority . absolute ownership . power . authority . jurisdiction . control . command ... power ....... power .......... power.
Rex Coil 7
Post by Rex Coil 7 » Tue Aug 04, 2020 9:21 am
Isn't that true about all very involved patches? A patch cable is a patch cable, no matter if it's zip-tied to a bunch of other patch cables or not. I suppose we all have our own ways of troubleshooting.
Return to “Play Out! Performance Modulars”
