Author |
Polychord confusion |
br>sgariplerden |
br>Hello,
I am little bit confused with the polychord function. To sum up the steps :
1. Activate the functionality with Poly + Chord Memory
2. For record, I play a chord and press on Poly + Chord Memory (red blink)
3. I select a key / I click on it and it is recorded
so the questions are :
a. does it work with any of the key on the keyboard ? it seems that it is not the case.
b. when working, if I have a C major chord on a single key, I can't play it simultaneously with for example a C3 note (so 4 keys played together)
c. can I erase a stored chord from a specific key ?
thank you for your help,
Samuel br> br> |
br>tubbutec |
br>1. yes
2. yes
3. yes
a) it works with any keyboard key
b) No you can only play one chord at a time
c) You can overwrite any chord br> br> |
br>sgariplerden |
br>tubbutec |
br>Hi,
WHILE playing a chord, you press POLY+CHORD. Then the led will blink and you can define the location to save the chord into. br> br> |
