Mannequins – Three Sisters Issue
ozmoziz
Post by ozmoziz » Wed Nov 20, 2019 8:28 am
Dear Wigglers,
I have a problem with my Three Sisters and wanted to know if anybody had a similar issue or has advise to solve the problem. Here the problem:
I have used the Three Sisters as a simple low pass filter (Osc into LOW and sound out of LOW). When I closed the filter (FREQ fully CCW) I could still hear the full unfiltered signal of the oscillator. This signal was much quiter than the filtered sound during filtersweeps but it was all the time present and hearable. The QUALITY knob was at noon, so the notch-effect shouldn’t be hearable. The unfiltered signal only disapeared completly when I turned the QUALITY knob to about 1 to 2 o‘clock which lead to an quite amount of resonance.
Thank you in advance
Peter
desolationjones
Post by desolationjones » Wed Nov 20, 2019 8:43 am
Three Sisters Quality knob: left of noon adds a phase-inverted copy of the dry signal to the mix, noonish should be full wet filter with small resonance, right of noon adds resonance. There is no way to get zero resonance on this filter.
ozmoziz
Post by ozmoziz » Wed Nov 20, 2019 9:36 am
desolationjones wrote:Three Sisters Quality knob: left of noon adds a phase-inverted copy of the dry signal to the mix, noonish should be full wet filter with small resonance, right of noon adds resonance. There is no way to get zero resonance on this filter.
I know that the Quality Knob CCW causes the mix with the phase-inverted signal, but the Quality Knob was at noon. I don't have an issue that I want zero resonance (I like the sound) but a had to dial in quite an amout of resonce to get rid of the phase-inverted signal (about 1 to 2 o‘clock).
BaloErets
Post by BaloErets » Wed Nov 20, 2019 9:41 am
Give this thread a read, specifically the 1st post. Sounds like its common to the Three Sisters (can't comment personally as I have never owned or used one)
viewtopic.php?t=168825&highlight=
ZargZorg
Post by ZargZorg » Thu Nov 21, 2019 6:35 pm
I can't fully close mine unless I have resonance slightly above 1
ozmoziz
Post by ozmoziz » Mon Dec 02, 2019 2:52 am
Thanks for your support. I guess I just missed this behaviour before :doh:
Will try to use this in my advantage :tu:
mdoudoroff
Post by mdoudoroff » Mon Dec 02, 2019 7:45 am
Three Sisters, Mangrove, and Cold Mac each have leaky features—it’s just not a design priority for Whimsical Raps. The leaky tendencies are part of their unique characters, so you let it be or patch around it.
atrostor
Post by atrostor » Tue Dec 03, 2019 6:21 am
That's true for Just Friends, too. The envelopes in Shape mode sit slightly above 0mV so the sound that's being enveloped leaks a tiny bit even when the envelope is fully closed. When I reached out to Whimsical Raps about this, they told me that this is a quirk of the module's design. Using an exponential VCA (and compensating for that with Curve controls) usually fixes this.
mdoudoroff wrote:Three Sisters, Mangrove, and Cold Mac each have leaky features—it’s just not a design priority for Whimsical Raps. The leaky tendencies are part of their unique characters, so you let it be or patch around it.
