Buchla format tempo synced lfos
xonetacular
Post by xonetacular » Sat Nov 23, 2019 2:12 pm
Wondering the best solution for this. I would like to add something to fill this role. In euro it was the xaoc batumi- before I get a blade adapter and just stick a batumi in there I'm wondering if there is anything else buchla compatible in 1u that will come close- either buchla/clone or 3rd party. Something with more control than just triggering a 281 from a clock divider or having to use the reset on an oscillator.
mritenburg
Post by mritenburg » Sat Nov 23, 2019 2:27 pm
Verbos 247v - it’s basically an 8 stage mini-marf that can be patched to provide clock-sync’d LFOs.
On the off chance that you already have a MARF or a 250e, those can be used the same way as the 247v.
If you happen to have a 257e, you can also use the slew processors to create an LFO from a steady row of gates; in effect giving you a sync’d LFO.
ArguZ
Post by ArguZ » Sat Nov 23, 2019 3:47 pm
8 LFOs...all attenuable...clock synced...freeze on demand.
8 waveforms...since, try, saw, square, random and more...
Phase offset, or frequency offset , extremely low ranges
xonetacular
Post by xonetacular » Sat Nov 23, 2019 5:46 pm
ArguZ wrote:Image
yes!!!
didn't know about these
and available diy too :love:
now I guess I will need to get another h module from them
ArguZ
Post by ArguZ » Sat Nov 23, 2019 5:51 pm
https://northernlightmodular.com/produc ... /h-series/
There is a whole line to choose from now...
And yes DIY and pre-built...
jimfowler
Post by jimfowler » Sun Nov 24, 2019 2:10 am
hED is great! I have two. Love me some NLM!
dougcl
Number 6
Post by dougcl » Sun Nov 24, 2019 2:31 am
251e plus slew. Set up four two stage sequences at different step durations. Or use four step sequences to slow even further, and so on. I use the 251e for this kind of timing all the time, almost exclusively.
xonetacular
Post by xonetacular » Tue Nov 26, 2019 10:44 pm
mritenburg wrote:Verbos 247v - it’s basically an 8 stage mini-marf that can be patched to provide clock-sync’d LFOs.
Ordered the northern lights kit but this still interests me. Where can I get a Verbos 247v?
