livewire frequensteiner low audio input orso
boombipbass
Post by boombipbass » Thu Nov 28, 2019 11:07 am
hi all
i have this beautiful frequensteiner but i rechanged my case and now its abrely hearable. even when i put the input and output at max i hear a low volume.
although when i let it resonace the full power audio comes out,
what coud this me?
boombipbass
Post by boombipbass » Thu Nov 28, 2019 1:14 pm
Its most left on my powerbus, is it because of that?
huffnPuff
Post by huffnPuff » Thu Nov 28, 2019 1:37 pm
boombipbass wrote:Its most left on my powerbus, is it because of that?
The position on the power bus should not matter - unless there's a broken lead or a bent pin or some such fault.
Try swapping positions and power cables with another module. Try different patch cables etc.
You solve such problems by systematic troubleshooting - try to come up with a list everything that could potentially cause this problem (e.g. faulty or reversed power cable) and eliminate them one by one.
:eek: :eek: :mad: :eek: :eek: :eek: :eek:
tuj
Post by tuj » Fri Nov 29, 2019 11:03 am
Check the mode switch. Sometimes it can become dirty and interrupt the sound. Try moving it and see if you get sound.
