What would you do with 58hp?
wet
Post by wet » Thu Nov 28, 2019 4:52 pm
Hi,
My case is almost full. I know I’m missing some modules that will enable me to get the most out of what I already have. I have 58hp left and the only thing I really want is an ER-301.
At first I didn’t want to get anything until the ER-301 because I know it can already do a lot on its own. But I’d like to make good use of my time while I wait and see how far 58hp can get me.
Without explaining what I already have... I’d like to know what you think the most important modules are that would fill that 58hp space. Would they also be useful if I had an ER-301?
nios
Post by nios » Thu Nov 28, 2019 4:53 pm
It's pretty hard to make any suggestions if we don't know what you already have.
wet
Post by wet » Thu Nov 28, 2019 5:13 pm
nios wrote:It's pretty hard to make any suggestions if we don't know what you already have.
I have a few sequencers, a sampler, drum module, 4 vca, mixer, clock modulators, clock generators, disting and a mutant brain that could probably go.
Agawell
Post by Agawell » Thu Nov 28, 2019 5:28 pm
if it were me i'd want to add maths, kinks and a doepfer sequential switch
which would still leaver room for the er-301
Sookilala
Post by Sookilala » Thu Nov 28, 2019 5:37 pm
Fill it with eurorack
Tomorrow Sounds Good
Post by Tomorrow Sounds Good » Thu Nov 28, 2019 6:26 pm
Rainmaker and a decent filter
sir stony
Post by sir stony » Thu Nov 28, 2019 6:51 pm
What do you use your disting for most of the time? Consider getting a dedicated, potentially better specialized module instead. It's hard to suggest anything in particular if you don't explain what kind of sounds you aim for typically.
VM
Post by VM » Thu Nov 28, 2019 9:25 pm
sir stony wrote:What do you use your disting for most of the time? Consider getting a dedicated, potentially better specialized module instead. It's hard to suggest anything in particular if you don't explain what kind of sounds you aim for typically.
Stereo reverb, sidechain compression, and delays.
Current curator of Perth Ambient.
Risc_Terilia
Post by Risc_Terilia » Thu Nov 28, 2019 9:31 pm
58HP is some people's entire system...
wet
Post by wet » Thu Nov 28, 2019 10:04 pm
Right now I’m just using it as an oscillator. Could probably use it for something better but I need it for an oscillator atm.
Sounds are hard to describe, but like some form of deconstructed grime and footwork, to faster paced jungle and gabber. I need to be able to use the modules live. I like random happy accidents. Generative.
MarcelP
Re: What would you do with 58hp?
Post by MarcelP » Fri Nov 29, 2019 3:24 am
wet wrote: Without explaining what I already have... I’d like to know what you think the most important modules are that would fill that 58hp space.
Is this a request for advice or a riddle?
dumbledog
Post by dumbledog » Fri Nov 29, 2019 2:49 pm
58HP? I might go slay those kobolds in the Cave of Dread depending on my equipment.
