Compressor/Limiter/Gate/Ducker..in one euro module ?
Midiot
Post by Midiot » Thu Nov 28, 2019 11:35 pm
This "limiter/ducker/compressor/gate" unit is often a standard 19" rack component in a recording studio setting, DJ usage......quite often for voice microphones, drum beats.....and other creative places.
Are there any high-quality units in eurorack ?..... that combine all of these in a single unit ?
"We'll be living in all the oceans now."
(type of music I make.... drone atmospheres, deep late-night beats.)
windspirit
Post by windspirit » Fri Nov 29, 2019 12:17 am
You can patch any of these with a VCA and an envelope follower ;)
leterell
Post by leterell » Fri Nov 29, 2019 12:31 am
WMD MSCL
Joe.
Wired for sound
Post by Joe. » Fri Nov 29, 2019 12:42 am
If you can DIY there's a great module from God'sBox called the Lollipop.
Compression with Sidechain, and two different modes (FET or Vactrol)
Midiot
Post by Midiot » Fri Nov 29, 2019 12:59 am
I used to own a Drawmer DS201 ducker/gate ....it was fun when I was working with XLR cables.
Or Klark Teknik, Valley People, or DBX.
Xinod
Post by Xinod » Fri Nov 29, 2019 3:24 am
Probably Gemini’s Path, the new module by Shakmat, does pretty much what you’re looking for in 6hp
Bishop Dust
Post by Bishop Dust » Fri Nov 29, 2019 5:16 am
Xinod wrote:Probably Gemini’s Path, the new module by Shakmat, does pretty much what you’re looking for in 6hp
Thanks for pointing that !
To be honest the Gemini's Path is not reacting like a real compressor or gate as it fires envelops on VCAs when a trigger is detected in the inputs or side chain input. So depending on your application it could be the perfect tool or not the tool at all (in case you are looking for something that glue your mix or a real limiter for example)
microfauna
Post by microfauna » Fri Nov 29, 2019 9:47 am
Midiot
Post by Midiot » Fri Nov 29, 2019 12:42 pm
So, is there a minimum "trigger" voltage to fire the envelope ?
Looks like it is a good tool for drums and beats. 6hp is nice.
Xinod
Post by Xinod » Fri Nov 29, 2019 12:55 pm
Bishop Dust wrote: To be honest the Gemini's Path is not reacting like a real compressor or gate as it fires envelops on VCAs when a trigger is detected in the inputs or side chain input. So depending on your application it could be the perfect tool or not the tool at all (in case you are looking for something that glue your mix or a real limiter for example)
yep, I realised it's not exactly what he's looking for but, as you said, it could somehow be...
Bishop Dust
Post by Bishop Dust » Fri Nov 29, 2019 4:03 pm
The module has an envelop follower with a gate detector the threshold is settable with a potentiometer. So it can be triggered by trigger, audio signal or modulation sources.
Bishop Dust
Post by Bishop Dust » Fri Nov 29, 2019 4:04 pm
Anyway thanks for pointing the Gemini :party:
Ras Thavas
Post by Ras Thavas » Fri Nov 29, 2019 4:12 pm
I've been looking around for a small gain/limit module for the feedback loop of my Harvestman Tyme Sefari MkII and noticed the Limit-L1 Triple Limiter.
http://dpw.se/product/limit-l-1/
brandonlogic
Post by brandonlogic » Fri Nov 29, 2019 4:54 pm
leterell wrote:WMD MSCL
+1 love mine
