three way SWITCH in Eagle
wahee
Post by wahee » Sun Dec 01, 2019 8:01 am
hi all
I am designing a switch system and need three inputs into one output
I have a toggle switch with 3 positions.
I can switch 2 positions ok
is there any way I can use the centre pin to have a third input.
I can do this with wire but I was wondering how to manage it in eagle, as I can't seem to find a way to connect the wires in any of the switch libraries I have.
I was hoping for an INPUT C straight down the middle , if that makes sense
Sorry if this is a dumb question.
yes I think this is daft as the centre pin is always connected so there is no way to 'switch' it to anything. I guess I need a 4 way switch. Just getting confused :doh:
Crystalline Stricture now on
tonnrecordings.com
Altitude909
Post by Altitude909 » Sun Dec 01, 2019 8:12 am
3 pins = 2 inputs + 1 output
you need a 4 pin device
revtor
Dialing it in..
Post by revtor » Sun Dec 01, 2019 8:13 am
You can create a part, it’s symbol, and it’s footprint. Then you connect the symbol pins to the footprint pads however you want.
Make sure to “use” your new part so it shows up when you “add” a part to your schematic
There are videos for this
chuckg
Post by chuckg » Sun Dec 01, 2019 9:53 am
You can use a "DPDT ON-ON-ON" switch, and wire it to behave as a DP3T switch. Here's one example. Ignore the confusing comments - they have mixed it up with a DPDT ON-OFF-ON switch, which is not what you want.
https://forum.digikey.com/t/wiring-a-dp ... a-sp3t/924
In this diagram, the common pin is at the center on the right. The three poles are: top left; bottom left; bottom centerish.
….working on it.
wahee
Post by wahee » Sun Dec 01, 2019 10:29 am
Ahh that's really good. That might just work if I can get some ON ON ON switches. I see how it's wired and I think that hopefully I have it right in this latest iteration:
tonnrecordings.com
wahee
chuckg wrote:You can use a "DPDT ON-ON-ON" switch, and wire it to behave as a DP3T switch. Here's one example. Ignore the confusing comments - they have mixed it up with a DPDT ON-OFF-ON switch, which is not what you want.
thanks for this!
tonnrecordings.com
cslammy
Re: three way SWITCH in Eagle
Post by cslammy » Sun Dec 01, 2019 10:51 am
wahee wrote:hi all
Hi Wahee
I am pretty new to this forum and can help out--karma, I hope.
after years of DIY/PCB fabs I feel I am OK at eagle.
Modifying a 2x PCB switch--DPDT, SPST, etc to 3x is pretty easy in eagle. If you let me know the size/spacing of the drills (a lot of time they are based on 100mil/2.54mm) and roughly the size pads you need I can create an LBR file and PM it to you. Or if you have a datasheet link that, they always have pad spacing info, or you can PM me if you want.
Also I have a blog post on how to modify eagle parts w/ some basic how-to links if you want to try it yourself--it took me a bit to get the hang of creating and editing EAGLE parts but once the skill was under my belt it changed my approach to DIY.
https://audiodiwhy.blogspot.com/2018/06 ... brary.html
EATyourGUITAR
has no life
Post by EATyourGUITAR » Sun Dec 01, 2019 12:40 pm
wahee wrote:Image
nope
wahee
Post by wahee » Sun Dec 01, 2019 1:21 pm
EATyourGUITAR wrote:
wahee wrote:Image
nope
It's maybe just the limitations of the eagle footprint I have, it can't show ON ON ON.
This should be better:
tonnrecordings.com
EATyourGUITAR
has no life
Post by EATyourGUITAR » Sun Dec 01, 2019 1:47 pm
wahee
Post by wahee » Sun Dec 01, 2019 2:28 pm
cslammy wrote:
wahee wrote:hi all
Hi Wahee
hi thanks for the help. I use the 320-938 switch from the switch library.
I have been kindly provided with the symbol but just have not got the knowledge to change the switch for another contact. If you can be bothered, it would be really cool:)
tonnrecordings.com
wahee
Post by wahee » Sun Dec 01, 2019 3:37 pm
Thats what I need, I just need to adapt it for a toggle switch footprint now
tonnrecordings.com
cackland
Post by cackland » Sun Dec 01, 2019 6:45 pm
Be sure to let us know the result :)
wahee
Post by wahee » Fri Dec 06, 2019 9:43 am
just as an update. I decided to use a 3pdt on on on slide switch.
Much easier to work with. thanks for all the input on this however
tonnrecordings.com
