4x Clock Divider > 4x EG > 4x VCF/VCA (low hp options?
tr34tm3nt
Post by tr34tm3nt » Tue Dec 03, 2019 5:44 pm
I'm somewhat new to modular and trying to gain some extra room in my almost full 204hp case. Wondering if you guys know any lower HP options for this module combo I like using.
4ms Quad Clock Distributor > 4ms Quad Pingable LFO in envelope mode > WMD Quad Attenuation > Sputnik Modular Quad VCF/VCA.
I've considered swapping the 4ms Quad Clock Distributor for a 4ms Rotating Clock Divider, but I've really grown accustom to turning a knob for divisions instead of re-patching cables.
Any thoughts or suggestions?
cg_funk
Re: 4x Clock Divider > 4x EG > 4x VCF/VCA (low hp opti
Post by cg_funk » Tue Dec 03, 2019 6:15 pm
tr34tm3nt wrote:I'm somewhat new to modular and trying to gain some extra room in my almost full 204hp case. Wondering if you guys know any lower HP options for this module combo I like using.
Hmm. I use a similar signal path often:
Integra Solum > Batumi > MI Blinds
Not exactly what you are looking for, but similar in some ways.
Intellijel has a sweet-looking quad-envelope module coming out very soon. Maybe look into a Quadrax instead of Batumi.
I don't know of any direct replacement for the quad VCF/VCA.. but maybe just get some different filters in small HP format.
Modulargrid: https://www.modulargrid.net/e/racks/view/1069607
The last session I recorded in the USA before relocating to Denmark:
https://soundcloud.com/mod_gene/zone-overture
wtk
Re: 4x Clock Divider > 4x EG > 4x VCF/VCA (low hp options?
Post by wtk » Tue Dec 24, 2019 2:15 pm
if x8 and /8 is enough range for you then maybe worth considering jakplugg's twiigs (dual branches). With twigs firmware flashed on both sides it turns into handy 4x clock divider/multipier, in 8hp and with fader or cv control
smithjohn
Post by smithjohn » Wed Dec 25, 2019 8:06 am
You could get 2x Takaab 2LPG, Meng Qi DPLPG or Make Noise LxD to replace the Sputnik Quad VCA/VCF but would lose the mode switches and summing. Those options would also be less spacious than the Sputnik.
One option could be the Future Sound Systems VAC1 quad passive LPG (6hp) and a small mixer.
Rigo
Post by Rigo » Wed Dec 25, 2019 8:56 am
Do you need all the knobs ? You could replace the envelope by the Doepfer A-142-4 Quad Decay, and use the A-132-4 Quad VCA.
