Behringer Go eurorack case
Tom_1970
Re: Behringer Go eurorack case
Post by Tom_1970 » Wed Sep 16, 2020 4:01 pm
Wow - nicely done!
I am not much of a DIY person, so I am quite happy it turned out this way.
WeepWow
Post by WeepWow » Sun Oct 11, 2020 11:45 am
Where can I get the Fixed Nut rails that fit my GO case if I decide to replace the sliding nuts? Will need 140 hp x 4 rails i guess. Thanks.
Supervillain
Post by Supervillain » Fri Oct 23, 2020 9:58 am
Hey, Just got one for sitting in the studio (and mainly to see how it is built)
I noticed some fuzziness from the modules metalic parts when i touch it, it the first case i got without grounded PSU so it might be normal but i doubt it...
Is anyone having the same problem?
If not i will return it
WeepWow
Post by WeepWow » Fri Oct 23, 2020 10:15 am
No noise here on my GO case. .... BTW, has anyone successfully retrofitted the GO case with the fixed rails yet?
I have some Tiptop 104 hp rails I can try, removing the GO case sides hopefully without a problem. Thanks.
SkyWriter
Post by SkyWriter » Fri Oct 23, 2020 10:26 am
Tom_1970 wrote:
Wed Sep 16, 2020 9:09 am
Made a cabinet for my 2 Eurorack Go cases.
Looking good! I did something similar with unstained (as yet) wood. Thinking about a third tier, LOL!
Prologue 16 - an adventure worth having!
twigathy
Post by twigathy » Fri Oct 23, 2020 6:46 pm
Not fixed rails, but I did swap out the nuts for threaded strips (Well, kind of). 2 pairs of 126hp strips (I got mine here https://synthracks.com/shop/eurorack-threaded-strip) plus the nuts that were included with the case jammed together were enough to cover 140hp.
WeepWow
Post by WeepWow » Fri Oct 23, 2020 6:59 pm
Awesome. when I'm feeling patient someday I will attempt the operation. :eek:
twigathy
Post by twigathy » Fri Oct 23, 2020 7:08 pm
It is honestly ridiculously easy. For each thing you want to add strips to:
  • Take all your modules out
  • Unscrew one end of a rail from the case side (This makes it easier to not just get nuts all over the place, I found)
  • Tip the case up a bit and angle the rail so the nuts fall out. Try and catch them rather than letting them spill all over the floor...
  • Put the threaded strip in and secure it with a normal module screw at both ends (This helped the strip not to fall out or anything silly like that. I found the Behringer rails were a little deep so the strip could kind of flip over on its side if I wasn't careful / didn't secure it in place a little before adding some modules)
  • Top up the remaining space with sliding nuts
  • Screw the rail back in place to the side
  • Repeat for the other 3 rails
At least, that's how I did it!
WeepWow
Post by WeepWow » Fri Oct 23, 2020 7:21 pm
Thanks for that, will try.
Also, when I got my 2nd Mantis case, I noticed the top rail row was too tight to fit some modules, so I just loosened the side hex screws a bit, gave the rows some breathing room then tightened after the modules were put in.
Tom_1970
Post by Tom_1970 » Sun Oct 25, 2020 5:12 am
Nice!
WeepWow
Post by WeepWow » Mon Oct 26, 2020 3:59 pm
Awh BUMMER ... Wanted to replace the sliding Nuts on the Behringer GO case- with Tiptop threaded strips.
So just tried to retrofit the threaded nuts strips from a Tiptop Happy Ending Kit (104hp) I have into the Behringer Go Rails. They dont fit...they are too wide. So, save yourself the trouble. I will need to order threaded strips that fit from somewhere.. Anybody out there know which ones will fit? Preferably a company in the U.S.
