Blacet ring mod functions
Acid Mitch
Post by Acid Mitch » Sat Jan 18, 2020 11:20 am
I bought a second hand Blacet ring mod and it came with switch position 3 not doing anything. The previous owner says it is broken. I have gave it to some one to fix and it would be handy to know what position 3 on the switch is supposed to do. Do any of you guys know what it does ?
revtor
Dialing it in..
Re: Blacet ring mod functions
Post by revtor » Sat Jan 18, 2020 11:27 am
Changes the “geometry” of how the carrier cv modulates the internal sine oscillator .. 1 does less of this, 2 does more, and 3 is the most modulation. May need a scope to get more specific about the effect. It’ll definitely produce a different effect that in settings one and two. Probably very dependent on the signals that you were running through the module, Which may make it hard to determine if the function is operating properly. You have to be very methodical when checking these things out, and a scope will definitely help.
Fellow North Jersey Synthaholic
Acid Mitch
Post by Acid Mitch » Sun Jan 19, 2020 8:09 am
Thanks :tu:
Rob_C
Post by Rob_C » Tue Jan 28, 2020 8:05 am
Spam reported and deleted.
Return to “Fractional Rack Modules”
