Choices barebones kit
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
sonicwarrior
Post by sonicwarrior » Wed Oct 13, 2010 8:26 am
What exactly is included in the Choices barebones kit?
flight
The Plague Bearer
Re: Choices barebones kit
Post by flight » Wed Oct 13, 2010 8:41 am
sonicwarrior wrote:What exactly is included in the Choices barebones kit?
Damn, I really need to get that page up, don't I?
Anyway, the CHBP comes with:
  • Assembled and tested PCB with 4-pin MOTM power header and 0.1" pitch headers for all panel components
  • Joystick with 4 mounting screws
  • Joystick panel cut-out template
  • 6 jacks with hardware and PCB connectors
  • 4 pots with hardware and PCB connectors
  • 4 knobs
  • One pushbutton switch with hardware and connector
  • two toggle switches with hardware and connectors
  • Power connector for 4-pin header
  • Assembly diagrams
  • Choices module owner's manual (because I haven't written the BP manual yet)
All wire-to-board connectors are Insulation Displacement Connectors (IDC) for 24AWG wire.
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
sonicwarrior
Post by sonicwarrior » Thu Oct 14, 2010 5:54 am
Thanks. :foh:
flight wrote:Damn, I really need to get that page up, don't I?
Would help. :hihi:
MrBiggs
I see dead people
Post by MrBiggs » Thu Oct 14, 2010 10:46 am
flight wrote:All wire-to-board connectors are Insulation Displacement Connectors (IDC) for 24AWG wire.
And when he says 24, he means 24. I used 22AWG and it was really a pain in the ass. It took a a lot of continuity testing to make sure it was all good. Of course I used a small flat-head screwdriver to shove the wire in -- ordering that little IDC key would help.
As Flight writes, the kit has everything except batteries and box.
•Music and stuff: Dance Robot Dance.
•Current contents:Modulargrid
flight
The Plague Bearer
Post by flight » Fri Oct 15, 2010 7:54 pm
Heh, that's why the instruction sheet says "a small flat-bladed screwdriver will be fine, just be careful". Shoving does not fall under "careful". ;)
~flight
IvanC
Post by IvanC » Wed Nov 03, 2010 6:26 pm
Two questions:
What is the recommended IDC punchdown tool for those connectors?
Do you sell a barer than bare bones kit (just the assembled PCB)?
Ivan
flight
The Plague Bearer
Post by flight » Thu Nov 04, 2010 12:57 am
IvanC wrote:Two questions:
See the attached PDF, and all of your questions may be answered. I made my own out of some metal strips, which I documented here and here.
Ivan
Yup, several options there. There's the CHBP- (without joystick) for $70.00, and just the CHBP PCB (assembled PCB with headers) for $55.
~flight
IvanC
Post by IvanC » Thu Nov 04, 2010 12:56 pm
Thank you; very helpful!
Ivan
stk
Post by stk » Thu Nov 04, 2010 6:54 pm
oops, wrong post box :doh:
flight
The Plague Bearer
Post by flight » Thu Nov 04, 2010 7:12 pm
LOL
~flight
stk
Post by stk » Thu Nov 04, 2010 7:22 pm
:youkids:
rico loverde
Post by rico loverde » Fri Nov 26, 2010 10:18 pm
hey Flight, just ordered a Choices barebone pack, I was curious if there are holes on the pcb for a eurorack style power header.
cant wait to build this, thanx for doing diy kits
works for Darkplace Manufacturing
flight
The Plague Bearer
Post by flight » Sat Nov 27, 2010 12:58 am
rico loverde wrote:hey Flight, just ordered a Choices barebone pack, I was curious if there are holes on the pcb for a eurorack style power header.
Yes there are, I assume you want that instead of the 4-pin?
You are welcome, thanks for getting one!
~flight
rico loverde
Post by rico loverde » Sat Nov 27, 2010 1:20 am
yea thatd be awesome, thanx again
Return to “Flight of Harmony”
