Resonant filter similar to Entity Perc synth?
bemushroomed
Post by bemushroomed » Fri May 22, 2020 7:25 am
What's out there that is similar to the External In filter etc on the SSF Perc Synth?
I had it for a while and what impressed me the most with it was the external input, how you could even affect pitch of the sound. I don't really know what the "pitch" is though, its obviously not sampling the sound and then pitching it.. I'd love to have a filter with same type of feature.
Any ideas?
edit:
This is what they say about the pitch feature btw,
"PITCH affects the frequency of the resonant filter. The nominal control range is from about 8Hz to 2.2kHz. This range is expanded upon use of internal and external control voltage sources."
bemushroomed
Re: Resonant filter similar to Entity Perc synth?
Post by bemushroomed » Mon Jun 29, 2020 9:10 am
No one?
second_breakfast
Post by second_breakfast » Mon Jun 29, 2020 9:36 am
I have the SSF Perc but haven't used the ext in yet. However, I believe what's going on is that you're sending an audio signal through a filter that has high resonance and is self oscillating so you're getting a mix of the ext signal and the self oscillation of the resonating filter. If you like the particular sound of the filter in the SSF Perc then try out the SSF stereo dipole filter. It shares similar sonic characteristics.
bemushroomed
Post by bemushroomed » Mon Jun 29, 2020 9:44 am
Thanks, yeah, i've looked at that filter it seems nice. Probably my next purchase then :)
Post by lisa » Mon Jun 29, 2020 9:48 am
When you send an external signal through the Entity Percussion you are sending it through a bandpass filter, a wavefolder (harmonics) and a VCA.
New track! Drum synthesis and melodies. ✨
bemushroomed
Post by bemushroomed » Mon Jun 29, 2020 9:59 am
aha, interesting.
Maybe i just should have kept it lol.. quite liked it for external in, but wasn't overly impressed with it as a perc synth otherwise.
NoLegs
Post by NoLegs » Mon Jun 29, 2020 10:02 am
Love the entity PS. One of my favorite voices out there for weird synth stuff and for actual percussion stuff.
