Modules for transposing sequences
Andy137
Post by Andy137 » Sat May 23, 2020 4:16 pm
Which modules can make fast transposing for sequences? Do I need ALM Beasts's Chalkboard only or should I look at precision adder?
mdoudoroff
Re: Modules for transposing sequences
Post by mdoudoroff » Sat May 23, 2020 4:20 pm
Doepfer A-173-1 and A-173-2?
(Particular solution may depend on what sequencers you’re using.)
Arneb
Post by Arneb » Sat May 23, 2020 4:56 pm
Beast's Chalkboard is a precision adder, it's just one without CV input and with manual input restricted to octaves. If manual octave transposition is all you need to do, sure, go for it.
greyscales
Post by greyscales » Sat May 23, 2020 5:02 pm
Disting has a couple of precision adder modes that work very well.
Beast's Chalkboard is a great octave switcher but only does octaves and no CV.
fjoesz
Post by fjoesz » Sat May 23, 2020 5:05 pm
hawkfuzz
Post by hawkfuzz » Sat May 23, 2020 5:09 pm
I think nothing beats the Tetrapad for this function IMO
THUMPR BC SC
Post by MindMachine » Sat May 23, 2020 7:02 pm
I'm checking out the ACL Oktave module.
bemushroomed
Post by bemushroomed » Sat May 23, 2020 7:05 pm
https://www.modulargrid.net/e/lpzw-modules-wk1
Just 2HP... best one i've found.
Andy137
Post by Andy137 » Sun May 24, 2020 4:56 pm
So as I understand, it can do any precision adder?
Arneb
Post by Arneb » Sun May 24, 2020 7:15 pm
Yes, in fact pitch CV transposition is the most important use case for precision adders.
moremagic
Post by moremagic » Sun May 24, 2020 9:09 pm
id recommend trying using one of your cv mixers before buying a module you might not even need
brandonlogic
Post by brandonlogic » Sun May 24, 2020 9:58 pm
I like A-185-2 because it has 3 way switches on every channel for add, subtract or off. If you don’t need to use all the inputs the normalizations allow you use those channels to add or subtract an octave.
The switches make using it a very hands on and performable... a bit more fun than your average precision adder.
I like the fact that it has 3 buffered identical outs, ideal for sending the same cv to multiple oscillators.
The top channel with the attenuator is cool too. It’s useful for adding some FM to your cv before it hits the oscillators, basically adding an additional fm input to them.
This comes in handy when taking advantage of the 3 outputs, sending the same cv to 3 oscillators because you now a single fm input for 3 oscillators at once, on top of 3 way precision adding and/or octave shits!
Joey P.
Post by Joey P. » Sun May 24, 2020 11:05 pm
Just picked up a Quantum Pax which is a combination of buffered mults and unity mixers that allows for 4-part transposition from combinations of individual part and global CV.
Before getting the Pax I was using an Intellijel buff mult and a couple unity mixers.
Andy137
Post by Andy137 » Mon May 25, 2020 3:34 am
So comparing ALM Beast's Chalkboard and Doepfer A-185-2 the second one looks more versatile and not 'one trick pony'.
aroom
Post by aroom » Mon May 25, 2020 3:55 am
check this thread:
viewtopic.php?p=2570133#p2570133
I've compiled a list of module who can handle pitch transpose
oilpanic
Post by oilpanic » Mon May 25, 2020 6:48 am
Trans Europa by Frequency Central can do this type of CV manipulation.
