Choices- tension screws missing
Gear, Suggestions and Discussion.
Moderators: Kent, computer controlled, flight
martin
Post by martin » Thu Oct 28, 2010 4:17 am
My Choices has 4 screws surrounding the joystick on the front and 3 empty holes where the tension screws are suposed to sit. What happened?
M
flight
The Plague Bearer
Re: Choices- tension screws missing
Post by flight » Thu Oct 28, 2010 8:34 pm
martin wrote:My Choices has 4 screws surrounding the joystick on the front and 3 empty holes where the tension screws are suposed to sit. What happened?
M
Oh yes, sorry about that, I forgot to update the instruction manual. The new joysticks (the old style joystick is no longer available) have four threaded holes in the body for mounting to the panel, which is good, but the tension cannot be adjusted on them, which is not so good. The panel still has the three holes because I'm using up the remaining panels in inventory before ordering new ones that don't have the three holes.
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
martin
Post by martin » Thu Oct 28, 2010 9:22 pm
Thanks for the explanation. The new joystick feels fine and the coned tip is nice too.
M
Return to “Flight of Harmony”
