Dawless Midi Control Change Recorder / Looper
djthopa
Post by djthopa » Fri Nov 27, 2020 4:13 pm
Hi,
Hope you are doing well and safe. :tu:
I was wondering if any body know of a external midi control change recorder / looper.
Ill explain my setup:
Im sequencing an mutable ambika synthsesizer with a external sequencer ( A vector Eurorack Sequencer).
I have a midi controller (novation launchcontrol) controlling some midi parameters on the ambika, and i would like to record / loop them without having to go trough ableton...or any DAW.
Does such device exist? Any recommendations?
I have been looking over the web and i have found the bastl midi looper but seems to be more for note / pitch information.
Thanks for your help!
wavejockey
Re: Dawless Midi Control Change Recorder / Looper
Post by wavejockey » Fri Dec 04, 2020 3:41 am
a(ny) MPC will record any MIDI info you send through it
but this can be interesting to you too : SDS Digital Sequarellel will record any MIDI you put into it and output MIDI + CV + it's mangling capabilities are "unparalleled" // http://www.freshnelly.com/sequarallel/sequarallel.htm
moloque
Post by moloque » Fri Dec 04, 2020 3:50 am
Oups didn't saw you mentioned it :doh:
djthopa
Post by djthopa » Sat Dec 05, 2020 12:53 pm
Hi! Thanks for the replies and tips! i have managed to setup with and ipad and touchable controlling ableton midi clips.
Wanted to stay away from computer, but it’s there anyways so might as well use it for more tasks.
Thanks a bunch
1040df
Post by 1040df » Sat Dec 05, 2020 5:40 pm
Potentially the Roland MC-707.
