Aggregate Device troubles
Moderators: Kent, os
Mans
Post by Mans » Thu Nov 04, 2010 12:47 pm
I have set an aggregate device as my default interface in Logic. The aggregate device consists of a Motu Ultralite mk3 and a Native Instruments Session I/O.
I insert the Step LFO on an instrument track, output to the Motu's 3-4, locked to transport, hit play and the Step LFO does not move.
If I then switch to just the Motu as my interface in the Logic audio preferences, the Step LFO does move when I hit play.
If I then switch back to the aggregate device, the step LFO continues to work.
It seems the Step LFO has trouble recognizing the interface when it is initially part of an aggregate device?
Post by os » Thu Nov 04, 2010 2:09 pm
Are you using the AU Generator version of the LFO?
Mans
Post by Mans » Thu Nov 04, 2010 2:21 pm
Yes I'm using the AU generator.
Post by os » Thu Nov 04, 2010 2:34 pm
Odd. The bug would be in Logic, if there is one. What version are you using?
Mans
Post by Mans » Thu Nov 04, 2010 4:17 pm
I'm using 9.1.1.
Post by os » Thu Nov 04, 2010 4:25 pm
32 bit?
Mans
Post by Mans » Thu Nov 04, 2010 5:17 pm
Yes OSX 10.5.8
Post by os » Fri Nov 05, 2010 4:23 am
I can't repro this problem (but I am on OS X 10.6).
Not sure what to suggest. Maybe report the bug to Apple.
Mans
Post by Mans » Fri Nov 05, 2010 10:55 am
No matter guess I'll use my 'preferences' workaround for now.
Return to “Expert Sleepers”
