Doepfer bus boards
revmutt
Knutty For Knobs
Doepfer bus boards
Post by revmutt » Sat Dec 13, 2008 6:36 pm
This could have gone here or DIY but it would have looked like an even dumber question there.
I am setting up a Eurocase with a different power supply but using the Doepfer boards. This power supply does not have multiple taps for the +/- connections.
Does that mean when I use two board I run into one's connectors and then out to the second board?
I looked at this http://www.doepfer.de/DIY/a100_diy.htm and I wanted to make music not build bombs.
Help
consumed
International Filter Conspiracy
Post by consumed » Sat Dec 13, 2008 7:10 pm
yes you can connect the power from one busboard to another--thats called daisy-chaining. it will work, but it has potential disadvantages for grounding/noise issues. a star configuration would be best. take a look at this page:
http://hotrodmotm.com/distribute_sod.htm
revmutt
Knutty For Knobs
Post by revmutt » Sat Dec 13, 2008 9:45 pm
Thanks consumed, Interesting. OK..
I wonder if the fact that this rack will have less modules will help keep things under control.
I will also ask the supplier of the power supply.
Soy Sos
Dub Surgeon
Post by Soy Sos » Sat Dec 13, 2008 10:04 pm
I used 2 terminal strips to split off the taps from my power supply.
I'm no expert but more qualified friends told me this would work and
it has. The case pictured has 4 Doepfer bus boards. I hope this helps.
revmutt
Knutty For Knobs
Post by revmutt » Sat Dec 13, 2008 10:10 pm
Thanks. Pictures always help.
I may luck out and only need one busboard on this rack as it is due to the grande sizes of some of the modules.
