Silent Way Is Teh Shizz
Moderators: Kent, os
TWINSTATES
Post by TWINSTATES » Thu Nov 11, 2010 11:52 am
The stepped lfo is ridiculously good for these reasons
1. Asym, my groove loves you!
2. Offset
3. Multiplier
4. The fact I can tweak using kore in high resolution then re-edit any glaring mistakes...
I was thinking about how I could apply the stepped lfo to pitch data is there a way of doing this without using external modules
When I play a note the stepped lfo would be applied using an envelope - i.e. there is no stepped lfo at the start of hte note but the shape of an envelope applies it and then reduces it over the time span of the envelope.
I lost a few hours playing around with 2 stepped envelopes on the same channel last night. Was sat in work thinking about how this could be done, and if it could be done without external modules
If anyone has any ideas then please let me know!
Post by os » Thu Nov 11, 2010 12:13 pm
Yes you can do that no problem.
Insert a Step LFO after one of the Voice Controller's envelopes. Set the LFO Input Mode to Multiply. The route the LFO output to the same audio output as pitch is going to, and let your DAW mix the two.
TWINSTATES
Post by TWINSTATES » Thu Nov 11, 2010 1:10 pm
Ahh, cool, I'll look forward to trying that tonight.
Thanks Os.
That questions begets another one...
Is there a way of making the stepped lfo conform to pitches? I am guessing that I would I use the quantiser for that after in the stepped lfo?
Many new things to try tonight :)
skweeegor
I can't believe I ate the whole thing
Post by skweeegor » Thu Nov 11, 2010 1:13 pm
Yup, quantizer after step LFO works great.
TWINSTATES
Post by TWINSTATES » Thu Nov 11, 2010 1:25 pm
is there a way to get a note bend as well? Slew I would guess? Am thinking that could be interesting...
I haven't used the quantiser so if there is a slew function apologies, I am just leaving work now so I can check when home...
Post by os » Thu Nov 11, 2010 2:47 pm
All plug-ins have the smoothing control. You could automate that on/off in your DAW.
TWINSTATES
Post by TWINSTATES » Thu Nov 11, 2010 6:24 pm
Ah, yes of course, smoothing = slew
Return to “Expert Sleepers”
