Basic question Monotron CV mod
omnisond
Post by omnisond » Sun Nov 21, 2010 8:53 am
I understand that I have to solder the tip of the cv 1/4 female connection (inside the outside box) to where it is marked pitch on the pcb, but where i have to solder the ground of that same female connection ? I know that there is a minus mark at the extreme right of the pcb but in that case, the gate, pitch and vcf will be weld to that same minus location on the pcb ? N.B : I know that I have to weld resistor inside the outside box.
Post by os » Sun Nov 21, 2010 9:09 am
You might have more luck posting in a more general forum e.g.
http://muffwiggler.com/forum/viewforum.php?f=4
sandyb
Post by sandyb » Sun Nov 21, 2010 9:31 am
os wrote:You might have more luck posting in a more general forum e.g.
indeed.
i'll move this to the diy section.
phono1337
2SK30A-O
Post by phono1337 » Sun Nov 21, 2010 5:40 pm
you can wire the sleeve of the jack to the battery ground terminal
full info at http://www.dinsync.info/2010/06/how-to- ... otron.html
epiphanius
Post by epiphanius » Tue Nov 30, 2010 2:55 pm
Thanks for this - I was in the same situation as the o.p.
