Expert Sleepers ES-2-2 module now available (EU, US soon)
Moderators: Kent, os
Post by os » Wed Nov 24, 2010 4:28 am
http://www.expert-sleepers.co.uk/es2.html
The Expert Sleepers ES-2 CV/Audio Interface is a Eurorack module designed for use with software such as Expert Sleepers Silent Way. It takes as inputs CVs from your analogue synths/effects on 3.5mm jacks, and outputs audio signals on 1/4" jacks which you connect to your computer audio interface. You then use the Silent Way CV Input plug-in to interpret the audio signal and output CVs in your DAW for recording, processing etc.
Scaff
Elbe Kontrollspannungsverein
Post by Scaff » Thu Nov 25, 2010 10:25 am
Is it also possible to record the output with a machinedrum and play it back from its memory?
If your system doesn't sound good enough, you haven't spent enough
Post by os » Thu Nov 25, 2010 10:42 am
You need to somehow recover the CV from the audio signal that comes out of the ES-2. In the demo I do this in software, in the CV Input plug-in. It could be done in hardware but it's not trivial.
Return to “Expert Sleepers”
