Question about the PB jacks?
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
bryantcheramie
Alopex
Post by bryantcheramie » Thu Dec 16, 2010 5:20 am
The four jacks to the right allow for two independent audio sources to be plugged in and two independent outputs?
CursedFrogurt
Square Enthusiast
Re: Question about the PB jacks?
Post by CursedFrogurt » Thu Dec 16, 2010 8:33 am
bryantcheramie wrote:The four jacks to the right allow for two independent audio sources to be plugged in and two independent outputs?
Not sure what you mean by the "jacks to the right," (I have the standalone device) but FOH jacks are usually wired as multiples. If you plug something into the input, the second input jack carries your input signal somewhere else to be fucked up in a second way. You *can* run two different audio sources into it, BUT you would be shorting the two sources together, which can be bad for certain modules if their outputs are not protected. Same goes for the rest of the jacks. This is convenient if you want to process audio in parallel (send your audio to four PB's, then mix the results together), or if you want a single CV affecting multiple parameters on the PB.
flight
The Plague Bearer
Post by flight » Thu Dec 16, 2010 2:52 pm
:agree:
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
TWINSTATES
Post by TWINSTATES » Fri Dec 17, 2010 4:24 am
Ahh that's interesting,
I would have thought that the 2 x input would be so you could put 2 input sources into the module...
flight
The Plague Bearer
Post by flight » Fri Dec 17, 2010 12:44 pm
TWINSTATES wrote:Ahh that's interesting,
No, it's really there as an alternative to stackable plugs (like bananas), but they can be used that way if the different signals come from sources with resistor-protected outputs, as mentioned in the Plague Bass thread:
As long as the two input signals come from resistor-protected outputs with equal-value resistors, then the two signals are averaged together: (s1+s2)/2. Changing the resistor ratio biases the ratio of the signal levels like a balance control.
~flight
Return to “Flight of Harmony”
