Choices pcb panel pattern
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
rico loverde
Post by rico loverde » Fri Dec 31, 2010 4:02 pm
Hey Flight, I was curious if ya might have a pattern for the hole placement for the pots and jacks so I can panel mount the pcb board. Just got a new skiff and need to make the choices module a bit shallower...
thanks Flight!!!
works for Darkplace Manufacturing
flight
The Plague Bearer
Post by flight » Fri Dec 31, 2010 7:15 pm
Here ya go.
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
rico loverde
Post by rico loverde » Fri Dec 31, 2010 7:30 pm
your the best, thank you.
flight
The Plague Bearer
Post by flight » Fri Dec 31, 2010 7:33 pm
And just in case, the template for the old joystick.
~flight
rico loverde
Post by rico loverde » Sat Jan 01, 2011 4:56 pm
are my pots the right way, i know the in and out need to be grounded, do the rest?Image
flight
The Plague Bearer
Post by flight » Sun Jan 02, 2011 2:09 am
rico loverde wrote:are my pots the right way,
Are you really asking me that? :hmm: The silkscreen on the PCB shows how they go. I have no problems answering questions but come on, seriously?
That depends on where the incoming signal comes from. If the signal comes from a module that uses the same power supply as the receiving unit, then no (banana jacks would not be usable otherwise). If the signal is coming from a source outside of the system, then it requires a ground reference for proper operation.
In short: ground all of them unless you have ground loop issues. That's the standard approach anyway - it's more versatile.
~flight
rico loverde
Post by rico loverde » Sun Jan 02, 2011 10:51 am
[/quote]Are you really asking me that? :hmm:
shit, i meant jacks. yeah id be a dumbass if i didnt fig out the pots.
sorry.
flight
The Plague Bearer
Post by flight » Mon Jan 03, 2011 8:51 pm
OK, now it makes sense. I thought it sounded odd...
S'OK! :sb:
~flight
Return to “Flight of Harmony”
