I noticed the following last night...
If I plug an AFG directly into the FrequenSteiner I get a clear, loud signal coming out of the FrequenSteiner. If I plug an AFG into a 138b then into the FrequenSteiner the signal degrades. It has to be at 7 or 8 just so I can hear something and that is muddy and barely audible. The signal doesn't even register on my audio interface. In order to get the same volume as AFG direct to FS I have to crank the volume knobs on the 138b to 10 in which case I get clipping, noise and distortion.
So I'm wondering a few of things...
Is this just normal signal degradation (2 patch cables, 3 modules as opposed to 1 patch cable and 2 modules)? Is this a characteristic of the 138b? For example people say not to use the 131 VCA because of distortion...does the 138b have the same issue? Is there a better mixer?
Thanks.
A-138b Mixer and signal degradation
Doepfer improved signal quality with the A-132-2 VCA but the A-138 mixers are still not high fidelity. Only solution at this time is the Plan-B Model 9 or Cwejman stuff.
http://www.REwireMusic.com
REwire's Analog Synth Collection
http://www.youtube.com/watch?v=S54LFP0s ... e=youtu.be
Re: A-138b Mixer and signal degradation
This sounds worse than typical, although it's been a while since I've used an A-138 for audio. Doesn't seem to me it was that bad. If you're a stickler, save and get the Cwejman VCA4-MX. This is really a great, compact module.jonkull wrote:It has to be at 7 or 8 just so I can hear something and that is muddy and barely audible.
- flippantminister
- 0118 999 881 999 119 7253
- Wiggling with Experience
