ADDAC System in other Formats ?
Hello all,
some people have bee inquiring me about other some modules in other formats, like 5U and frac, i have been restraining myself from doing it, but if enough people are interested i'd be willing to do it.
let me know!
best
andre
let me know!
best
andre
- mike sheridan
- Wiggling with Experience
- emergencyofstate
- Synthesist
Hello,
from what i could read here:
http://www.elby-designs.com/panther/euro-frac.pdf
seems that it does fit, it’s only 4mm smaller in height due to the eurorack lip, don’t know about the holes spacing though!
it works with -+15V but what type of busboards does FRAC use?
i could do an adapter cable i guess...
for an extra amount, i could also do a custom one in FRAC or any other size, i'll check the standards and if the pcb dimensions are compatible i can make a custom panel next time i put a panel order!
what i can't do is use banana plugs or 1/4 inch jacks!
they're too deep for my pcb designs...
PM me if you wanna go for it!
- emergencyofstate
- Synthesist
Thanks for providing that elby-designs link, very good reference. I had seen that a long time back but now i have saved the pdf.
I have a mixed system: bugbrand modules use the small MTA 100 size headers and Blacet have the larger ones (not sure of the name)
bummer the .wav can't be outfitted with bananas! but I can live with that if I have to.
Anyway, I'll be PMing you. 8_)
- AnalogBastard
If you could do limited editions in Eardrill's ModuleModule format or in the standard Buchla format, that would be cool. You'd have to take a good look at what is already on offer though and decide which items might be of most benefit to the 200/200e user.
I will caution you about stocking up too many Frac versions. Just ask STG and Flight of Harmony regarding sell-through rate on Frac.
- mecanikill
- Electrical Demon
- opsysbug
- Super Deluxe Wiggler
Kent wrote:![]()
Buchla?
Eardrill ModuleModule?
Bueller? Bueller?
Just checking in.
Cassette/DL here:
http://loveallday.bandcamp.com/album/the-driscoll-mala
Other improv stuff.
https://soundcloud.com/matt-hannafin
Other improv stuff.
- sonicwarrior
I'd like to have the VC filterbank in 5U. MU preferred but MOTM would be OK (although until now I only have DIY modules in there).
Soundcloud
For sale: Jürgen Haible Tau Phaser (MOTM format)
- monstrinho
I didn't see anyone else answer this old question - the power plug for Blacet's Frac modules and Wiard 1200 frac modules is the same as MOTM IE 4-pin 0.156" with the 2 centre pins being 0v.__ag wrote: it works with -+15V but what type of busboards does FRAC use?
I would be interested in frac versions of some of your modules IF you could make them with blue panels.
