How many Piston Honda roms have their been .
Digital Audio Electronics - discussion & support.
Moderators: Kent, solidox, governor blacksnake
amnesia
Post by amnesia » Sat Feb 19, 2011 4:50 pm
I hate these sub forums. I keep forgetting they are here. I only look in eurorack for eurorack stuff.
We need a list of PH Roms available.
I keep missing ROMs
sandyb
Post by sandyb » Sat Feb 19, 2011 5:01 pm
read the relevant threads in this subforum and make a list for the community then ross :razz:
amnesia
Post by amnesia » Sat Feb 19, 2011 5:05 pm
its a full time job in itself trying to keep up. :-P
sandyb
Post by sandyb » Sat Feb 19, 2011 5:07 pm
it's only two threads iirc.
shouldn't take you long.
thanks for your contribution to the site :)
amnesia
Post by amnesia » Sat Feb 19, 2011 5:13 pm
my biggest problem is I seem to spend 12 hours a day here ...I need to either sell my modulars, love synthesis less, love Muffs less or get off my ass out of the studio and see the sun
But if I do that its more stuff to catch up on. I know I should have just stayed with one modular format :-)
bsmith
Post by bsmith » Sat Feb 19, 2011 5:30 pm
Let's see, David Hylander is burning Stretta's:
Vector 1
Vector 2
Bosch Gardens
Morphine
Vowels
Paper Kettle homies offer:
mµtown:
Pocket Monster µP (Serge Creature ROM)
PLL µP (Schumann PLL ROM)
Brainrom
1 µP
downloadable only:
Sonic the Hedgehog set
Yours truly set:
udder (my own)
new.256 (included with the wave256 software)
allophones (from wiard group)
monowave (from wiard group)
Phase Ghost:
viewtopic.php?t=30067
there are also some chebyshev's flying around out there, which is also on the wiard list.
Surely there are more in use the people have been bouncing around and definitely a bunch that folks are rolling their own.
sandyb
Post by sandyb » Sat Feb 19, 2011 5:31 pm
thank you brandon :tu:
amnesia
Post by amnesia » Sat Feb 19, 2011 5:52 pm
Thanks Brandon
I have ordered your ROMs from AH.
Do I have to take out the already inserted extra Harvestman chips to run your ROM's?
jbartee
special stage
Post by jbartee » Sat Feb 19, 2011 5:53 pm
There's also my Sonic The Hedgehog set. Not available pre-burned though, hex / .256 download only:
viewtopic.php?t=28357
rico loverde
Post by rico loverde » Sat Feb 19, 2011 5:57 pm
hey bsmith do can i buy yrs directly from u?
works for Darkplace Manufacturing
amnesia
Post by amnesia » Sat Feb 19, 2011 5:57 pm
How do you burn a ROM? What do you need etc?
I only know how to insert them.
sandyb
Post by sandyb » Sat Feb 19, 2011 6:14 pm
bsmith
Post by bsmith » Sat Feb 19, 2011 6:35 pm
amnesia wrote:Do I have to take out the already inserted extra Harvestman chips to run your ROM's?
You can Do As Thou Wilt with any of those rom slots on the expander with any valid rom, just point them in the correct direction, the little notch is a solid guide. The expander comes with two which occupy the C&D slots, there are 4 remaining empty slots, so you have 6 slots to play with.
amnesia
Post by amnesia » Sun Feb 20, 2011 12:32 am
thanks sandy.. you know I love this place too much :-)
Hey I actually stayed off the internet for 5 hours!
mckenic
pew!pew!pew!kthnxbye!
Post by mckenic » Sun Feb 20, 2011 12:48 am
Better than me!
Its 5:47 am, Deep Space 9 season 7 is playing in one window and Im still trawling around here (thinking of Piston Honda obviously!) :hmm:
jiblite
fail
Post by jiblite » Sun Feb 20, 2011 11:50 am
:75: + :75: + another 20 dollars for these
Vector 1
Vector 2
Bosch Gardens
Morphine
Vowels
ow - thats a wee bit costly compared to the rest!
Looking for 500 PB Fastener 3030580 black/grey soft touch knobs
Beware of Lawrence (larrydecable) - proper skam merchant
sentinel6
Post by sentinel6 » Sun Apr 24, 2011 12:28 am
I am curious as to why:
"the Scale Quantizer would not work well with the Piston Honda." (as per hylander.com)
Thanks in advance...
jbartee
special stage
Post by jbartee » Sun Apr 24, 2011 7:28 am
sentinel6 wrote:I am curious as to why:
Because the Honda's output range (in voltage) differs somewhat from the miniwave, so you don't get a 1v/octave scale unless you very carefully attenuate the output.
Someone should put together a Honda quantizer rom that is calibrated properly -bet people would eat it up.
bsmith
Post by bsmith » Sun Apr 24, 2011 7:34 am
I've tried to build a quantize rom just for the ph and gotten *pretty* close - but no cigar. Maybe someone (like you jbartee!) else would have success, but the 256 sample distances are just off to tweak up chromatic solidly for the ph at 1v/oct, at least as far as I was able to tell. Best I've come up with is to just apply a smidgen of gain between the ph and the oscillator using the quantize tables on the new.256 rom. Takes a little effort to find the exact gain point where it will work, but it's quite usable once that's found with a .bam or inner channel of maths or whatever.
http://soundcloud.com/bsmith-1/piston-h ... pp-to-anti
edit:
And ps, just feeding a slow ramp or triangle into the ph in ext mode turns it into a fantastic cv modulation source.
and pps another method besides a .bam or maths gain is just to apply an offset to the singal in a linear vca...
Rod Serling Fan Club
aquatic hitchhiker
Post by Rod Serling Fan Club » Mon Jul 11, 2011 7:35 pm
I saw this link on the SDIY mailing list. 4300 single cycle waves! Could be a great resource for peopel burning their own.
http://www.adventurekid.se/akrt/wavefor ... waveforms/
John Noble
Pining for the fjords
Post by John Noble » Mon Jul 11, 2011 8:39 pm
Rod Serling Fan Club wrote:I saw this link on the SDIY mailing list. 4300 single cycle waves! Could be a great resource for peopel burning their own.
Holy waveform overload, Batman! :bacon:
I dug around in the files with a hex editor and a checked what I found against a WAV format reference page. The AKWF files are:
-- 600 samples
-- 16 bits (1,200 bytes of audio data per file)
-- nominal 44,100 samples/second.
wave256 format has 256 8-bit samples, so to translate these would require more than just decimation from 16 to 8 bits. I'm looking around for a suitable library to resample these into the right format and package them up properly for testing in the wave256 editor.
Those are some verrrry interesting waveforms! :burns:
a scanner darkly
Post by a scanner darkly » Tue Dec 13, 2011 4:30 pm
Saw this on S/B/T forum, reposting here for reference:
http://www.paperkettle.com/home/m%C2%B5town/
bsmith
Post by bsmith » Tue Dec 13, 2011 4:37 pm
right on, had those there and just didn't realize the group was collectively known as mµtown - post above edited. Hey if anyone else has others they're making available for download or selling or that are flying around out there please pm me so I can stick them up in that post above for posterity.
a scanner darkly
Post by a scanner darkly » Tue Dec 13, 2011 5:15 pm
Thanks Brandon! Just bought an expander and your set as well as paper kettle's - looking forward to hearing them :tu:
I hope the new expander doesn't get sidelined with all the new stuff coming out...
Starrefision
Post by Starrefision » Thu Mar 01, 2012 6:10 am
phase ghost rom added to list.
Return to “The Harvestman”
