FreqDiv Mod - LPF 'Q' Selection Switch
wait, what?
Post by Muff Wiggler » Sun Aug 19, 2007 12:45 am
The Frequency Divider has a DIP package on the PCB with three settings for the onboard LPF, off, on, and on (steeper). I like to replace this DIP package with a panel-mounted 3-way switch
carefully clip the four leads from the DIP package to remove it, and solder the contact to a 3-way switch.
You can see the switch I made for the panel in this pic (sorry it's so blurry)
BananaPlug
Post by BananaPlug » Sat Jan 30, 2010 6:14 pm
The manual says there's four possible levels of filtering (including none). It appears to be a binary setup where closing one contact has more effect than closing the other and there are four possible on/off combinations.
So what did you end up with on your switch?
Blacet:
As the PCB legend implies, placing the #1 switch actuator in the up position results in the least filtering, followed by #2 in the up position, and both #1 and 2 in the up position. If both #1 and 2 are down, there is no filtering.
e-grad
Post by e-grad » Sat Dec 17, 2011 5:50 am
BananaPlug wrote:So what did you end up with on your switch?
I'd like to know as well.
I'm thinking about a expander panel for the 12 outs plus to on/off switches to choose btn all four possible filtering levels.
idiotunderground
Post by idiotunderground » Sun Feb 03, 2013 2:27 pm
bumping this- i'd like to know the answer too!
making a panel now to squeeze all 12 jacks on there, would like to add the switch but i'm not sure which i should use :hmm:
alesauskas
Post by alesauskas » Mon Jun 10, 2013 2:25 am
I'm gonna bump again, for the same reasons as previously stated: I'll be making this panel soon and would like to know if I need two switches or if the way muff has it rigged is the way to go.
Tubeampguy
Post by Tubeampguy » Sun Jun 22, 2014 11:01 pm
alesauskas wrote:I'm gonna bump again, for the same reasons as previously stated: I'll be making this panel soon and would like to know if I need two switches or if the way muff has it rigged is the way to go.
I'm going to bump this yet again! :eek:
:tu::blacet: :tu:
monstrinho
Post by monstrinho » Tue Jun 24, 2014 10:07 pm
If I understand the schematic correctly, you'd need two two-pole switches (assuming you want all four filter possibilities brought out to the front panel).
Return to “Fractional Rack Modules”
