MOTM-730 VC Divider modules are ready to ship!
Author MOTM-730 VC Divider modules are ready to ship!
paults
Received the first set of 15 MOTM-730 VC Divider production boards.
Every function checks out 100%!
There other 85 CPU boards will arrive ~ 1 week. I will be able next
week to ship the first 15 orders in the backlog for the '730. I will
type up a Owner's Manual this weekend, and I will post
the *binary* firmware files for the 2 PIC processors (one is in a socket
the other soldered into the board). The socketed IC is the main CPU
divide engine, the smaller soldered IC just drives the display. The PICs are OTP (one-time programmable) so a dedicated programmer is needed
to replace them if one dies and I'm not available for a replacement smile
I do not expect these PICs to die anytime in the next 10 years or so.
The measured power supply current is:
+5V @ 75ma (no outputs driving). Add 4ma/driven (patched) output.
+15V @ 16ma
-15V @ 14ma
The outputs are 0 to +5V square waves for the dividers, and an analog
'stepped' sawtooth wave that steps in 4th/octaves/5ths.
All divider outputs can be used simultaneously, as long as your supply can handle it. A MOTM-950 supply can handle 5 '730s, driving ALL the outputs from all 5 as well as a MOTM-650.
Info and demos at:
www.synthtech.com/new_stuff.html
So . . . if someone was to buy a MOTM-950, 5 '730s and a MOTM-650 will you throw in a free 12 space rack??? Mr. Green
I'm really looking forward to my MOTM-730!!! hyper hyper hyper
paults
a) I have added the PDF user manual at the URL in the first post.
b) I'm having a MOTM-730 Patch contest. $200 for first, $100 for second. If you win, it's a 50% off module It's peanut butter jelly time!
So, order a MOTM-730 and get patching! Deadline is March 20th.
