Drum modules and modular triggers
sgnhh
Post by sgnhh » Fri Feb 06, 2009 6:40 am
I've been thinking about my drum sounds situation and believe I've come up with a solution, maybe one that someone here can test. If I get a drum module, say an Alesis D4, and plug the trigger outs of some of my synth modules into its inputs, will the D4 trigger as if it were receiving triggers from a fake kit?
Post by Kent » Fri Feb 06, 2009 7:01 am
In the manual, there should (I'd hope) be a notation as to the triggering spec of the D4. Usually, it is just a voltage threshold. If the synth in question can fire off a signal that is hot enough, it should work.
dkcg
Post by dkcg » Sat Feb 07, 2009 3:17 pm
I would think the signal is hot enough if it's coming from a modular. :deadbanana:
consumed
International Filter Conspiracy
Post by consumed » Sat Feb 07, 2009 3:23 pm
sure, it should work fine. whats your trigger source and what does the drum module trigger input require?
criticalmonkey
Post by criticalmonkey » Sat Feb 07, 2009 3:47 pm
i can try it for you later tonight - i have a dm5
criticalmonkey
Post by criticalmonkey » Sun Feb 08, 2009 12:10 am
yep it works - kinda - tried it with my a149-2 random cv and korg sq10 with my DM5 and roland td10
didn't dig to deep - just enuff to know i don't wanna do it to often
149-2 - under control of 149-1 clocked off an lfo
with alesis dm5 - it seems to trigger on the off
with td10 - it triggered on both the on and the off of the cv (2 hits when i expected 1)
with the korg seq
trigger out -
dm5 - triggered every time - got all sorts of weird re-triggering - attenuating might help this, just odd behavior
with the td10 - trigger on on and off when using a trigger out
whe using the normal cv out-
dm5 - same weirdness with added "velocity"
td10 - it triggered on change - i.e. if 2 steps where set the same then the second trigger was skipped - but this seemed the most like i would have expected
works best when you just send an audio pulse to either of them - just have to set input levels - you get better velocity too
this is what i'd do if i needed
not sure why you would want to do this - after doing it, I kinda felt like i lost most the abilities of the drum module
although living voltage is kinda cool - :confused:
off to the thread about to many options....
sgnhh
Post by sgnhh » Sun Feb 08, 2009 9:20 am
Thanks for the info.
consumed
Post by consumed » Sun Feb 08, 2009 1:05 pm
the 149-2 appears to put out gates rather than triggers. if you're going to test it, i would recommend sending triggers to the modules instead. i see that the D4 is designed to trigger from incoming audio so you'd definitely have to experiment with it.
Cat-A-Tonic
Lobsters love Muff
Post by Cat-A-Tonic » Sun Feb 08, 2009 5:26 pm
My Boss Dr. Pad III gladly accepts triggers from the modular.
Hitting the pad itself is more dynamic though. (pressure -> amplitude)
Plugging in an external trigger does not disable the pad.
So you can use both simultaneously for little fills.
I have yet to try making the triggers more dynamic by varying their amplitude and/or width.
I'll get on that soon.
Sometimes I think about getting a Roland HPD-10.
It is so much fun to play with the demo unit at the gear shop.
It has an external trigger input too.
So I think you can trigger one sound (bass drum) from the modular.
I tried the HPD-15 too, but I liked the samples better on the HPD-10
even though there are fewer of them.
criticalmonkey
Post by criticalmonkey » Sun Feb 08, 2009 6:06 pm
"the 149-2 appears to put out gates rather than triggers. if you're going to test it, i would recommend sending triggers to the modules instead. i see that the D4 is designed to trigger from incoming audio so you'd definitely have to experiment with it."
that's why i did the sequencer too - :guinness:
consumed
Post by consumed » Mon Feb 09, 2009 12:35 am
criticalmonkey wrote:"the 149-2 appears to put out gates rather than triggers. if you're going to test it, i would recommend sending triggers to the modules instead. i see that the D4 is designed to trigger from incoming audio so you'd definitely have to experiment with it."
ah ok--korg you said--i missed that part :guinness:
i wonder if an alesis module expecting audio for triggers would expect an ac signal.
it would be interesting to take the trigger and offset it to center around 0V.
