Pulse/Trigger samples to run the modular with a sampler/daw?
Exuviae
Post by Exuviae » Wed Mar 30, 2011 4:55 pm
Anyone have wav files of this type to share or know where to find such a thing?
Brooks
drewtoothpaste
Post by drewtoothpaste » Wed Mar 30, 2011 5:02 pm
Exuviae
Post by Exuviae » Thu Mar 31, 2011 6:36 am
Thanks, Drew!
doctorvague
ole fuckity fuck
Post by doctorvague » Thu Mar 31, 2011 8:11 am
I created some wav files at different levels.
They're in a zipped folder here:
http://idisk.mac.com/doctorvague/Public ... AWSync.zip
They're all 5ms long.
Exuviae
Post by Exuviae » Sun Apr 03, 2011 8:23 am
Thanks guys! Gonna check these out this week.
VortexRanger
reticulating splines
Post by VortexRanger » Thu Apr 07, 2011 12:51 am
Some audio input modules will create a trigger for you too... like the Q118, which is what I use. It also creates a gate and an envelope, and you can set the threshold at which it creates these things... much fun. :yay:
http://www.synthesizers.com/q118.html
Automageddon
Post by Automageddon » Thu Apr 07, 2011 1:52 pm
Can I just load this pulse in Live and use it to for example, reset a LFO or sync a sequencer?
haven
Post by haven » Thu Apr 07, 2011 3:42 pm
Automageddon wrote:Can I just load this pulse in Live and use it to for example, reset a LFO or sync a sequencer?
I put mine into Simpler and make clips with various rates, eg one every 16th, 8th etc all the way to every 8 bars for things like resets. Route a couple of those simpler tracks to individual outs and use them for clocks and resets etc.
These tracks with all those clips are great to have in the Live library.
Automageddon
Post by Automageddon » Fri Apr 08, 2011 8:13 am
I managed to make this work last night without any problem.
Strangely enough my MFB dual Lfo would not reset from the -10Db, so I had to use the -6Db and put the simpler output to -0 (it's usually on -12Db by default).
Apart from that, all worked like a charm.
I had the midi out to the modular on one midi channel and simpler on another, but both were receiving midi from the same in.
YONI
Post by YONI » Fri Apr 08, 2011 9:12 am
I use two outs from my MPC1000 sending these triggers - One to clock a sequence, another to trigger envelopes. LOVE it. I've been trying to find a sample I can use as a gate for my adsrs, but had no real luck - any ideas??
Johnisfaster wrote:Its obvious that this is an FBI cover up. Ive no doubt YONI is already dead.
YOU SAW NOTHING!
Mikeyg3k
Post by Mikeyg3k » Tue Mar 14, 2017 6:46 pm
Is this possible to do from say Logic Pro X using a Scarlette 2i2 sound card routing that somehow to clock my modular?
