does the POWER require a busboard?
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
jah_vengeance
Post by jah_vengeance » Fri May 06, 2011 9:54 am
13″ Doepfer-style 18AWG wire harness with quick-connect connectors
yo. I was thinking of sorting out a small skiff thing and powering it using the foh "power", but unsure of what this sentence means:
"13″ Doepfer-style 18AWG wire harness with quick-connect connectors"
is that referring to something like the daisy chain power connector that comes with the Makenoise "din power" module, or is it basically just some leads which you connect to a bus board (such as one by doepfer)?
looking to make something as compact as possible, so not sure I could fit a doepfer bus board in the skiff i had in mind.
cheers!
weinglas
Post by weinglas » Fri May 06, 2011 9:59 am
My power modules had no bus boards, just the cables for connecting to two Doepfer busboards each.
RealDudes
Lives in a Dudeplex
Post by RealDudes » Fri May 06, 2011 10:08 am
the quick connectors are little wires that have connectors that slide on to the terminal of the busboard and appear to be the same style as guitar speakers. I'm waiting for a MW busboard right now. from the picture on their site it looks like it has terminals that are fastened by tightening a screw down onto the stripped wire. I dunno, all I have right now is a foh power module. patiently waiting for the rest
goiks
Hardest Tryer
Post by goiks » Fri May 06, 2011 10:40 am
the foh power module has spade connectors and leads, no flying busboard. it's a nice solution if you have 75mm or so to work with and can have a busboard.
for a minimalist skiff, check out the power solutions from make noise, they are the shallowest.
www.goike.com
"There is no right answer. Just compromises." - Dave Jones
"Intelligence is generated by communities, by cooperation of some kind." - Brian Eno
flight
The Plague Bearer
Post by flight » Fri May 06, 2011 12:32 pm
Power bus/distribution boards are in development and should be available pretty soon. I'm also looking into alternative distro options, I'll let you know when they're ready.
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
jah_vengeance
Post by jah_vengeance » Fri May 06, 2011 2:08 pm
thanks for all the info.
good to hear you are planning some distribution thing mr Flight.
I was needing to sort something out by the end of this month for a skiff, so might go for the tiptop power thing.
cheers again.
supersuper
Post by supersuper » Thu May 12, 2011 6:12 am
It would be nice to see how those who have the power modules have used them. Pictures please!
goiks
Hardest Tryer
Post by goiks » Thu May 12, 2011 10:57 am
www.goike.com
qu.one
hypnotic and sanctified
Post by qu.one » Thu May 12, 2011 11:03 am
^^^^ awesomeness
wavehead
Post by wavehead » Fri May 13, 2011 4:35 pm
flight: what is this alternative distro board you are talking about? understandable if you aren't talking about it yet, but i hope this is something like a star ground distribution or anything else that might be an improvement on the standard doepfer busboard.
CursedFrogurt
Square Enthusiast
Post by CursedFrogurt » Fri May 13, 2011 4:52 pm
Man every time somebody posts in this thread the FoH subforum lights up, and I think "oh boy, if I click on that I'll get another dose of noise and terror" only to find out it's more conversation about BUSBOARDS.
Return to “Flight of Harmony”
