ADDAC802 questions
Moderators: Kent, __ag
cathartech
ADDAC802 questions
Post by cathartech » Sun May 22, 2011 2:51 pm
what kind of curve do the vcas have? also, how do the initial knobs interact with the vca cv in? does it react well to negative voltages?
i'm interested in this module primarily for long, smooth fades as opposed to am blippyness... but hopefully it can do both reasonably well.
cathartech - alchemical sonic research
cathartech
Post by cathartech » Fri May 27, 2011 5:24 pm
nm. picked one up.
here are my observations:
tricky to use as a standalone audio mixer (no vca inputs used) as the signal abruptly fades in at noon. there's no signal from full ccw to 11:59, unless you have a vca connected. when an envelope is attached to the vca input, full ccw - 11:59 seem to provide the output of the vca only. noon to full cw seems to gain the vca and gain the input signal for a layered effect.
i believe the curves to be exp. it AMs really well, and it seems to saturate pleasantly. it's very useful for animating, but not the best solution as a standalone mixer. i've found attenuators to be really useful, allowing one to control the levels of the channel from 0-11:59 by attenuating the vca before the addac802.
i'll try to get a vid in at some point.
Arcade Sinusoid
Post by Arcade Sinusoid » Tue Apr 24, 2012 7:57 pm
Thanks for the info cathartech! When you say abruptly fades in at noon does it just jump from no sound to in your face? Just looking for a little more info on this module :despair: If you could give me some more knowledge on it I would appreciate it.
cathartech
Post by cathartech » Tue Apr 24, 2012 8:41 pm
actually, it turned out that the first release (which the this review was based off of) was bugged. the new versions of the module are, with no cv input, silent at full ccw and increase in volume as expected as you turn the pots cw. high cv can still overcome a full ccw knob in some instances though...i've found using the trimpot on the back allows one to dial in the response to alleviate that. the trimpot also allows for saturation of the signal at high levels.
Arcade Sinusoid
Post by Arcade Sinusoid » Tue Apr 24, 2012 9:07 pm
Thanks for the information cathartech. Really appreciate it!
Garz
Post by Garz » Sun Feb 04, 2018 2:24 pm
Hi! i´m thinking about get an ADDAC802. Now, I´m using the MI Frames as a mixer for my system with a pair of vcas and I want to replace the vcas and the Frames with the addac.
The Frames acts like a attenuator before the signal goes to my audio interface. If I use the output of the vcas directly to my audio interfaces the signal is too loud and sounds really bad, even if i put down the signal in the audio interface.
My point is... could i attenuante the signal of the input with a cv envelope connected to the module, from zero to his max?
I don´t know if the attenuator of the ADDAC802 channel attenuates the volume or the envelope of the cv input...
Summa
Post by Summa » Sun Feb 04, 2018 6:16 pm
Garz wrote:Hi! i´m thinking about get an ADDAC802. Now, I´m using the MI Frames as a mixer for my system with a pair of vcas and I want to replace the vcas and the Frames with the addac.
https://vimeo.com/87696724
https://vimeo.com/87697267
Garz
Post by Garz » Mon Feb 05, 2018 10:00 am
mmm seeing the video , if the knob is to his max, the signal is not affected by the cv input... so probably the knob attenuates both ..
Return to “ADDAC System”
