Introducing VS3 of ADDAC001 Voltage Controlled Computer!
Moderators: Kent, __ag
__ag
Post by __ag » Thu Jul 07, 2011 8:25 am
accurate timing is most of all a programming issue, like you might know there's ways to keep digital clocks very accurate, this could easily be implemented
but what would you consider a high clock rate in terms of milliseconds?
stk
Post by stk » Thu Jul 07, 2011 6:15 pm
I personally can't imagine using rates faster than several tens of millis, I had just heard of people having trouble with the Arduino not "keeping up" under heavy load.. But then I have not reviewed their code, so..
Anyways great work, I've been waiting a while for someone to finally tackle a project such as this :tu:
asterisk
Post by asterisk » Thu Jul 21, 2011 8:26 pm
i tried a V.1 of the ADDAC brain module and as i said before, the arduino could only really handle about 4 channels of CV output of fast data generated in max/msp at a time before it started to glitch and stutter quite a bit.
unless the processor of the arduino is vastly improved, i dont see how you could get all 8 channels plus inputs and gates and everything happening using fast data rates from the computer. ive talked with andre about this and i feel like this module is maybe a bit impeded by the speed of the arduino processor.
thats why i was saying, id be interested to see / hear demos of V.2 to see if any of this stuff has been resolved or things work more smoothly.
__ag
Post by __ag » Fri Jul 22, 2011 6:28 am
Hello Greg,
I still think you were making some mistakes while using the vs1, I tried debugging them with you but you never sent me the max patches or code so that I could advise you on a proper implementation
This is not a a standalone module, there's a learning curve to it, and there's good and bad ways to do things in such a system....
This is also not a simple bridge between the computer and the modular, this is a module that can be a lot of modules you might have or want, through code you can definitely replicate some module behaviors or create your own algorithms ...
Anyway I am very aware of the speed issue, but like I've been stating here this won't be good for ex. super fast lfos, but like you can see in my last oscilloscope videos, they can still go pretty fast, no glitches or whatsoever.
Best
Andre
bkbirge
Post by bkbirge » Fri Jul 22, 2011 12:27 pm
This looks like a very cool module. With the cv input expansion would it be possible to make a nonlinear cv to cv mapping? I'm thinking to tune metasonix stuff to follow 1v/oct reliably but it could also be used as a scale table for microtuning.
Modular & Dork Rock:
https://bkbirge.bandcamp.com/
Racks:
https://www.modulargrid.net/e/racks/view/88730
https://www.modulargrid.net/e/racks/view/89177
https://www.modulargrid.net/e/racks/view/379579
"The person who says it cannot be done should not interrupt the person doing it." ~ Puck, 1903
bj_gzp
Post by bj_gzp » Thu Aug 04, 2011 4:59 am
bkbirge wrote:This looks like a very cool module. With the cv input expansion would it be possible to make a nonlinear cv to cv mapping? I'm thinking to tune metasonix stuff to follow 1v/oct reliably but it could also be used as a scale table for microtuning.
This is one of the main reasons i got my brain for: Custom Midi/CV and CV/CV conversions. Not for the metasonix, but for BBD's.
A full Math's clone may be ambitious, but logic processing and burst generators, should be easy for a developer.
I'm working on a preset management system for the envelopes.
So that i can recall a specific envelope setting from max and still be able to modulate any of its parameters in realtime by Midi/CV.
I'll always use a manual or CV in for the sustain level if it's pitch related, cause the 7 bit midi resolution is not precise enough.
Once i have this working, i'll make the max patch and ADDAC code available on my website.
Björn
jjr
max/msp and the ADDAC001
Post by jjr » Sat Jun 02, 2012 12:17 pm
hey guys
I'm really interested in using the ADDAC001/VCC with max msp. Some of the details of how this works is a little above my head but I'm trying to understand.
Say - I wanted to send a cycle object in MAX to the VCC and have it control a analoug VCO . DO I have to add special objects into my patch for the VCC and the cycle object to communicate?
Do I have to add special augments or features to the Cycle object to get it to map properly over 5 volts?
Does all data coming out of max into the VCC have to be in the 0 - 1 range?
any information on this process would be most helpful and appreciated.
best
jjr
vqlk
Post by vqlk » Sun Dec 02, 2012 9:22 am
so if i bought this and the cv in expander, i could have input cv's into max and then send some of them back out after processing?
that seems insanely powerful, but i'm definitely not feeling the love for this module.
why?
i'm out, go circle someone else's corpse.
vqlk
Post by vqlk » Sun Dec 02, 2012 9:42 am
and without that connection, a can still run operations on the cv's in, like the radcore but 4 times as many ins/outs and in greater resolution??
vqlk
Post by vqlk » Wed Dec 05, 2012 5:22 pm
will someone tall about this some more cos i can't find a manual... is it crazy to [with the cv adapter] use this instead of buying a few envelope generators, maths, etc..
space really...
DonKartofflo
The knob-twisting Hive Mind
Post by DonKartofflo » Wed Dec 05, 2012 5:56 pm
not at all, been thinking about the same thing lately!
Nelson Baboon wrote:Beware of people who tell you to smile.
FS:
Mutable Instruments Tides 1 120€
Addac sys 12U powered frame 200€
ws9848
Post by ws9848 » Tue May 14, 2013 4:04 pm
does anyone have any videos of the VCC in use? I only found a couple of the ADDAC demos. also, the user guide wasn't working on the website. is there one out there somewhere?
Phetus
Post by Phetus » Mon Jun 03, 2013 4:04 pm
Does anyone know where I can get the usersguide pdf? The link on the website doesn't work.
Return to “ADDAC System”
