SoS normal behavior?
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
nuketifromorbit
Post by nuketifromorbit » Sat Jul 02, 2011 8:50 pm
Ok before I begin let me state that I read the manual and I'm extremely happy with this module( its pure fucking evil :twisted:) Anyhow I've noticed that when I turn the rate knob all the way counter clockwise the delay signal simply disappears and if I attempt to turn the rate knob back in a clockwise direction, a pop will occur and the delay signal once again kicks in. Basically is this normal behavior for the SoS?
flight
The Plague Bearer
Post by flight » Sat Jul 02, 2011 10:48 pm
Mostly yes. When turning CCW, the delay starts to get glitchy around 9:00, and will disappear entirely around 8:30 (these positions may vary a bit due to component tolerances), so there is a dead spot from 8:30 to full-CCW. Turning it back CW past the glitchy point - so past about 9:00 - brings the delay back. As for the pop, I'm not sure exactly, but what is heard depends on your feedback, insert, and input settings.
Glad to hear you like it otherwise though!
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
nuketifromorbit
Post by nuketifromorbit » Sun Jul 03, 2011 1:53 am
After playing with the insert, mix, and feedback knobS the so called pop was pretty much gone. Not surprisingly it tended to occur when a hot signal was being fed into the module and one of my envelators were modulating the rate at audio level. Judging from others videos I'm pretty sure its more or less just the clickity chaos that ensues when you push this thing to its limits.
Return to “Flight of Harmony”
