plague help
Gear, Suggestions and Discussion.
Moderators: Kent, computer controlled, flight
bluemeanie
wiggle me wiggle me wee
plague help
Post by bluemeanie » Mon Jul 18, 2011 1:35 am
i've realised that after installing some attenuators for the high and low cv inputs on my bare bones kit...
...with nothing connected to any of the cv inputs, the 'high cv attenuator' produces a small sweep thru the high parameter. by itself. if that makes sense..
this doesnt happen with the low cv attenuator.
where are the volts coming from i wonder?
the attenuators were originally wired in wrong ( the in and out of the pot were mixed up ) :yay:
this was fixed and i cant think of any other way that i could have messed this up. it seems so simple no?
anyways , can someone else who has some attenuators installed for the high and low cv confirm they dont have the same happening please?
thanks heaps
nodules on my modules
www.soundcloud.com/s-k-p
bluemeanie
Post by bluemeanie » Mon Jul 18, 2011 10:21 am
actually ..... after a bit closer look it does also happen with the low cv attenuator as well. all pots are at 12:00 except low pot at 3:00
the funny bit is if i patch a totally separate attenuator into each of the cv in's (with nothing connected to the attenuators input) i can also sweep the low and high parameters..
..so... anyone got a PB and an attenuator to check for me?
none of this bothers me unless i'm gonna blow something up.. just interested
many fanks
flight
The Plague Bearer
Post by flight » Tue Jul 26, 2011 6:55 pm
I recall encountering this myself while messing around with the PB in the past... IIRC, it was a very small range of sweep though, and barely noticeable.
Could you post a diagram of your wiring please? That would help in figuring this out.
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
bluemeanie
Post by bluemeanie » Sat Oct 08, 2011 11:42 pm
soz, i forgot i started this thread :oops:
i have made no attempt to fix this cause its a nice addition i've found.
Tsarik
Post by Tsarik » Sat Oct 15, 2011 1:52 pm
haha.. i like how you took a problem and made it a tool
i don't know much.. i mean nothing at all about electricity and analog synths... my future retro xs was easy to grasp.. so was the SEM... but some of the modulations between the 2 weren't what i expected
working with the quad plague bearer isn't easy... but it has been immensely rewarding and proven its worth many times over... i don't know what it is exactly i'm learning.. but i'm finding sweet spots and modulations and amounts that work really interestingly.... its just an amazing device that drives my creativity
i'm glad he builds them though... kits are attractive in price but out of my league... i have more money than patience... or i should... because i have no patience
Return to “Flight of Harmony”
