pedals with exp. inputs?
jimmyambulance
Post by jimmyambulance » Wed Aug 24, 2011 9:10 am
any favorites?
delays with exp pedal control of delay time?
fuzz with exp pedal control of... uh... fuzz?
dkcg
Post by dkcg » Wed Aug 24, 2011 11:38 pm
Moog seems to be ahead when it comes to CV inputs and outputs in effects pedals. I love my Moogerfooger Phaser. I think it's got the most ins of all my pedals.
Modulation Maniac
Post by zerosum » Thu Aug 25, 2011 1:44 am
I have been wanting One of these LAL Superoscillo88's forever...
Damn I want one....Still! :lol:
The Malekko E600 and Spring Chicken have epression pedal inputs which is why I want them and will one day have them :yay:
tuj
Post by tuj » Tue Aug 30, 2011 7:55 am
WMD Geiger Counter. With an expression pedal, it is sick.
Post by MindMachine » Sat Sep 03, 2011 1:24 am
Both A/DA Flanger and Final Phase have cv inputs. Many of the newer Electro-Harmonix delay pedals have cv inputs.
blahquaker
Post by blahquaker » Sat Sep 03, 2011 5:06 pm
most of the copilot fx pedals have exp inputs.
smetak
Post by smetak » Thu Sep 08, 2011 9:29 pm
tuj wrote:WMD Geiger Counter. With an expression pedal, it is sick.
I second that. A Geiger and an expression pedal - what else can one ask for?
smetak
Post by smetak » Thu Sep 08, 2011 9:30 pm
Oh, and I would add the Empress Delay with the Exp. pedal for the feedback - got some crazy noise with that - the control is just nirvana.
Joe.
Wired for sound
Post by Joe. » Thu Sep 08, 2011 9:59 pm
:nana: Boss RE-20 Delay :nana:
For those that like Raggae and dub (and can't afford an RE-201 Space echo).
Only one EXP input, but you can choose a few different functions (not during operation though, you actually have to switch the unit off, then resett it to change the function)
REPEAT RATE:The echo interval becomes shorter as the toe of the expression pedal is pressed further. In Long mode, the range for the Repeat Rate setting is twice that of Normal mode.
INTENSITY:The Intensity increases as the toe of the expression pedal is pressed further, increasing the volume of the echo repeat sound (the feedback volume).
ECHO LEVEL:This controls the level input to the echo. The volume of the echo sounds increases as the toe of the expression pedal is pressed further.
* This function can be controlled only with an expression pedal.
* The input level to the reverb is not changed.
TWIST:Repeat Rate and Intensity are controlled simultaneously.
In addition, this controls the ECHO VOLUME according to them echo level. As you further press down on the toe of the expression pedal, the echo sound starts to oscillate, then the oscillation rate increases and the pitch of the oscillation sound rises.
Holy Katana
Post by Holy Katana » Sat Sep 17, 2011 12:30 pm
I'm pretty sure a fair bit of EHX's stuff has EXP in.
