Wish list
Author Wish list
Jari Jokinen
Why not put it here too? Maybe some of the smaller manufacturers are seeing this.
"I took time to type my little wish list. What do you think?
- Non-DIY adapter for Yamaha breath controller (I am surprised, that this is not a popular request.)
- New version of A-164-1 with better pushbuttons and more compatible gate signal (A-164-1 is to be discontinued, so not much hope.)
- Continuous fast action push button a la Ondes Martenot (Could be useful in the Monster base for example.)
EDIT: With gate and trigger outputs too
- Pitch to voltage converter
- Quantizer not limited to positive voltages only (There are workarounds,
but...)
- Midi interface not limited to 0V - 5V range
- A module similar to Serge NCOMP voltage controlled divider + comparator
- Pulse/trigger divider capable of multiple odd divisions simultaneously
- A simple fluctuating random voltages module (Maybe Make Noise Wogglebug will fill this function.)
- 16 step sequencer
- 9U suitcase with built in multiples (The space seems to be there.)"
makenoise
Absolutely, the Wogglebug will fit that bill.
Re: the Serge NComp, couldn't this be done with A combo of the Comparator and VC-Divider from DOepfer?
Re: divider with multiple odd divisions. Will the Flame Clockworks do anything like this? I have not read that manual yet, but it seems possble.
Re: push-buttons. I am working on some control modules which will bring these features.
Re: Pitch to Voltage. Analog Systems has P to V module. I do not know the number, but I have seen the module working pretty good with guitar.
Tony
Waz
- What I really want to see is an easy way to buy a subrack without importing it from Australia or sifting through industrial serial numbers for the right schroff. very frustrating
- A simple Powering solution that doesn't cost an arm and a leg.
- 1/8" jacks with a built in mult like a banana cable. (is this even possible?)
- VCS
- A folding case like the Buchla one, but in euro fashion
- I REALLY want to see something like the TKB, but for a more open system like frac and euro.
- And a never ending glass of beer.
wetterberg
actually, one might find that the Doepfer a-163 vc divider works quite well as an N-comp replacement altogether - I'm not 100% but I think that most Doepfer sort of "logic" modules have comparators on the inputs to square up signals.
- you won't get the weird staircase output, though...
A Dingleberry Monstrosity
ASys makes a nice pitch to voltage converter.
Jari Jokinen
Good!
They may do the job. In fact, I already have A-167 Comparator. The A-167+A-163 16HP combo just doesn't seem elegant to me.
It doesn't seem to do odd divisions. Attached picture is from the manual. Someone correct me, if I am wrong
Good to know.
It is RS35. I haven't seen a demo exposing its raw performance. I have always wanted a pitch to voltage converter, but after all it might not be as much fun as one might expect.
Jari Jokinen
Those would be really useful, if they had mechanically good feel. I use multiples a lot.
That would be nice too. Some euro modules are quite deep though.
wetterberg
actually most are less than 10 cm deep. Should be doable, even though clearly not as slick as the ultra-flat Buchla.
haven
Jari Jokinen wrote:
- 16 step sequencer
the Doepfer sequencer can do this. Your will need two A-155 sequencers and a A-154 Enhanced Sequential Controller. the two A155 can then link into a 16 step sequencer.
To me it makes sense to sell it in parts like this so that those that can afford and need the 16 steps can get something flexible - and everyone else can still afford a basic sequencer.
I have no experience with the Doepfer sequencers however. I use a Machinedrum as my modular sequencer for now.
Jari Jokinen
Can they be "played" fast?
Jari Jokinen
haven wrote:
Jari Jokinen wrote:
- 16 step sequencer
I had A-154 and one A-155. 16-step sequencer can be patched using A-150 voltage controlled switch(es). Adding second A-155 only gives more channels. Apart from extra patching required for 16 steps, there are some quirks.
I would like an uncompromised 16-step sequencer and then something like Mini-Milton
dougcl
Recently I've been thinking about how cool it would be to have a three channel, VC equalizer, just like the Cwejman VCEQ-3, but with individual outs. Each individual out would then have an output (gate) indicating an overload condition on the channel. It would be a way of interrogating an inbound audio signal regarding its frequency content (at least in three bands) and generating gates off of it.
felix
I know only a little about vocoders, but it sounds like it would be perfect for something like this - especially if it had comparators for each envelope follower.
I talked to Dieter Doepfer about something quite similar to this. I am looking for a MIDI to trigger converter that is velocity sensitive and is scaled to at least +10VDC on the high end of the scale. He said that the firmware of their A-192 could be adapted to be velocity sensitive and that perhaps the unit could be modified for what I was looking to achieve. I have to say that he was quite a gracious gentleman. He's going to talk to his firmware guy.
Jari Jokinen wrote:
16 step sequencer
What about the 2 Doepfer models and the 2 models of Analogue Solutions' Oberkorn?
Jari Jokinen wrote:
16 9U suitcase with built in multiples (The space seems to be there.)"
The Schneider's booth had a modified g6 suitcase with the multiples built in on display. Foretelling of things to come?
Jari Jokinen
Judging from the first video, RS35 seems to track ok.
Nice
MAQ16/3 and Schaltwerk: I am looking for more analogue functions, inputs etc.
Oberkorn: Quality issues (?) Might be the best bet.
Modcan: Not available with minijacks (I asked).
Jari Jokinen
Montag
-a modular tape delay grin help
-touch plate interface for euro
-power starvation (I think FoH is working on this?)
-a fully functional osc that allows the user to draw/shape the basic waveform
more when I remember...
criticalmonkey
+! on the touch plate/trigger idea for euro
Veqtor
My wishes:
A 16 in, 16 out digitally controlled polarizing matrix mixer with preset storage in a non-volatile memory, which can morph between presets via cv or midi control.
A compact clone of the buchla timbre waveshaper
Montag
Oh, and I really want a:
-Neural Agonizer in Euro
SoundPool
mini-EQ. like an elf module. something simple like a little 3 or 4 knob EQ that has a fairly steep response
mixer that has mute switches
modular harmonizer, or at least an octave/partials down unit that gives you more options than a square wave
some sort of oscillator bank other than the ones from MFB
