Euro dual Teezer?
appliancide
Post by appliancide » Sat Mar 02, 2019 9:09 pm
frijitz wrote:
appliancide wrote: Horrible Mistake
Could you please elaborate on this? The 1V/Oct trimmer does not connect to ground. There are several versions of this board, so I'm not sure which one you are refering to, but in all the trimmer connects to a 330R resistor (R16). Could you possibly please post a photo showing this particular connection you are talking about?
Ian
No pictures :doh: :oops:
I'm sorry Ian, but that problem and solution may have had a bit too much assistance from Hamms. :beer: :oops: Just popped the module out, immediately saw the problem that had been "fixed" before. The PCB is perfect, sorry for the bad information! I've removed it from the original post.
frijitz
Post by frijitz » Sun Mar 03, 2019 4:58 pm
appliancide wrote:I'm sorry Ian, but that problem and solution may have had a bit too much assistance from Hamms. :beer: :oops: Just popped the module out, immediately saw the problem that had been "fixed" before. The PCB is perfect, sorry for the bad information! I've removed it from the original post.
Ah, that’s the problem—you need a better brand of beer :lol:
That design is so old and has had such an unfortunate history, I’ve lost track of all the different versions and corrections. Glad to hear you cleared up this issue.
Ian
MuadMusic
Sync Level pot connections
Post by MuadMusic » Sun Apr 07, 2019 2:03 pm
Since I had to research this, I though I'd add a note. The Sync level pot is connected to the J2 connector as follows:
viewed from the rear, with lugs on the bottom,
rightmost lug (CCW from front panel perspective) connects to ground
middle lug (output) connects to S lev 2
leftmost lug (CW from front panel perspective) connects to S lev 1
synthcube
you will be assimilated
Post by synthcube » Sun Apr 07, 2019 2:13 pm
frijitz wrote:
sduck wrote:Do these boards use the CA3280? Edit: oh, now I see, they do. But i also see you sell them, so I guess that sorts that out. For a while you couldn't get those things anywhere.
Actually, they are being manufactured now by Alpha:
http://www.alfarzpp.lv/eng/sc/AS3280.php
Alex kindly sent me a couple to test, and they looked fine in my usual VCA-like test circuit. :banana:
Ian
these new alfa 3280 chips will breathe new life into ian's already-awesome designs!!
facebook: https://www.facebook.com/2SynthCube
synthcube webstore www.synthcube.com/cart
music from outer space: www.musicfromouterspace.com
blacet research: www.blacet.com
MOTM DIY Analog Synthesizers: www.motmsynthesizers.com
music from outer space euro smt: www.mfoseuro.com
