[BUILD] - CGS Euro Modules
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page Previous  1, 2, 3 ... , 19, 20, 21  Next [all]
Author [BUILD] - CGS Euro Modules
bkbirge
Cool, didn't know about the BOM import tool.
Tall Midget
Also here's some of the parts needed for the Funky Drummer:
clarke68 wrote:
Gated Comparator Sequence pots are all 100k linear.
Here's all of the switches on the Funky Drummer:
Pulse Divider Reset - Mouser #633-FB15ANEP2
Note actual part number is 633-FB15ANEP2-xy, where x is the size (F = small, H = large) and y is the color (C = red, A = black, B = white) of the button cap. This part is pretty critical, as the hole in the panel is specifically sized for this switch. Good quality switch, tho...tested to 50k cycles.
Gated Comparator Manual Loop/Load - Mouser #633-M201901-RO
There are probably other switches that will fit here, just be sure you get one that's ON - OFF - (ON)
Digital Noise Clock & Gated Comparator Loop Enable - most any SPDT ON - ON will work, the mounting holes are 0.25 in. which seems typical. I used part #317236 from Jameco.
Tall Midget
Hey Brian, I already posted one in the other thread, it's just an Excel spreadsheet but it works with mousers BOM import tool. It needs some work described below to it but it's mostly complete. The only things missing AFAIK are the 22k (25k) trimmer for the Serge Voltage Controlled Filter and the 22k-25k trim for the CGS VCO. I'm not even sure if the other trim-pots I specified are still in stock. That's all that's keeping me from starting the project are the trim-pots. I'm not sure if I made the changes for 12 volt operation listed above either. If someone were to make it a complete BOM that'd be really neat.
Tall Midget wrote:
I didn't include the knobs or jacks, too tired to add them or count them now but most of the parts are there I think. Potentiometers are Mouser Part #'s but I would order them from somewhere else other than mouser to save money. There are a few Digikey part # that aren't specifically listed as being from Digikey but if Mouser doesn't recognize a part number when you import it, odds are it's a Digikey part number.
Edit: Check out the updated BOM bkbirge posted on Page 3 of this thread.
bkbirge
Can't wait to get started on a funky drummer and mini synth. Anyone got one of those shareable mouser project BOM's going yet? If not I'll see about putting a couple together, they make ordering (after the first time) so much easier.
simfonik
negativspace wrote:
50k logs @ Mouser - 313-1500f-50k
w00t Thanks!
negativspace
simfonik
Based on the rear panel image for the MSU, it looks like I need the following potentiometers:
(10x) 313-1000F-100K
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV16AF-10-15R1-B100K/  ?qs=sGAEpiMZZMuarXojuOTsc9jR33G5hGO%252bcj2YiaooI6I%3d
(1x) 313-1000F-1K
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV16AF-10-15R1-B1K/?q s=sGAEpiMZZMuarXojuOTsc7XUj8Kk%2f1Ts8uwZ%252baquuNs%3d
(1x) 313-1000F-1M
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV16AF-10-15R1-B1M/?q s=sGAEpiMZZMuarXojuOTsc7XUj8Kk%2f1TscFmzyHqZdKI%3d
(1x) 313-1000F-20K
http://www.mouser.com/ProductDetail/Alpha-Taiwan/RV16AF-10-15R1-B20K/? qs=sGAEpiMZZMuarXojuOTsc3UoKTY4nCEoKqEqi3d3N6w%3d
(1x) 50k log .... can't seem to find this at Mouser or Jameco.
Does that look right? Any idea on the 50k log pot? dizzy
clarke68
I went through Ken's site and did a quick search for everything written about building these PCBs for use with +/- 12v. If you find (or know of) any other 12v mods, please post it and I'll keep this list updated.
CGS29 - Wave Multipliers
While untested, the module should work on +/-12 volts.
CGS77 - Serge 1973 VCF
Will run on +/- 12 volts or +/-15 volts.
CGS35 - Steiner VCF
Version 1.3 can be built as shown on the overlay of the PCB ... For use with +/-12 volt supplies, the two diodes marked with rings around their pads on the overlay should be replaced with links.
CGS114 - DUSG / CGS75 - VCS
CGS48 - VCO
The module will work on +/-12 volts if the 20k resistor connected to pin 3 of the LM311 is reduced to 14k.
CGS13 - Gated Comparator
Resistors RA and RB form the voltage divider that determines the gate output voltage. Use 1k for RB. When running off +/-15 volts use 1k8 for RA. When running off +/-12 volts, use RA = 1k5.
CGS31 - Digital Noise
CGS36 - Pulse Divider/Boolean Logic
VER1.3 PCBs have the upper part of the output dividers marked as RA on the PCB. These resistors are 1k8 for +/-15V operation and 1k5 for +/-12 volt operation. Likewise the two 1k8 resistors in the inverters should be 1k5 for 12 volt operation. The two 1k5 resistors in the OR and AND gates could probably be increased to 1k8 for 15 volt operation. Check your output voltages when you have assembled them. Ideally the voltages will swing between 0 volts and +5 volts. Some small variance either way is nothing to be concerned about.
falafelbiels
SMS303 wrote:
jenamu6 wrote:
Paying you to screw up components and a PCB?
Me thinks.....NO!!!
d'oh! hmmm..... !LOL! Mr. Green
In Casper we TRUST! SlayerBadger!
eek!
clarke68
Monobass wrote:
did you post the details of what knobs you used somewhere?
They're in the first post of this thread, too, but I'm happy to repeat:
My knobs are from Jameco. Obviously you can use any knobs you want, but it will help if you get the size close. Sizes and Jameco part #s are:
small - 0.55" - 136241
medium - 19.8mm - 264990
large (on MSU only) - 33.3mm - 264946
negativspace
Part #s from Jameco are listed in the other thread. thumbs up
I'm going to try some black aluminum ones from Mouser, they had one line that worked for all 3 sizes and wasn't stupidly expensive - I hope they don't suck.
scozbor
yes these panels have barged in and jumped my DIY queu!
Monobass
man I can't wait to start mine...
apfEID
these are beautiful, I hope I find time to start doing some DIY next year...
clarke68
jenamu6 wrote:
Could these panels and designs be easily bananafied?
Depends what you consider easy. The jack holes are all sized for 3.5mm jacks...about 6mm. The banana jacks I've used require about 8mm, so you'd have to drill out all the jack holes. Not too bad a job if you're fairly comfortable with a drill.
Beyond that, I think there might be one place in all of these panels where I assumed a normalized connection would be implemented...may have been in the Funky Drummer, I can't remember.
RealDudes
they look like architecture models
we're not worthy we're not worthy we're not worthy
clarke68
RealDudes wrote:
Can we see a pick of the completed backside of one of these beauties? they look SlayerBadger!
I just updated the "PCB Mounting" post on the first page with these (and a few other) photos:
That's as far as I've gotten in my builds. At this point, I expect some of the other guys will have boards populated and modules screaming before I do...keep your eye on this thead!
SMS303
Me thinks.....NO!!!
jenamu6
SMS303 wrote:
That should be possible, imo ....
Jean will you build them or ..... ???
If you're not...
I'm still busy with 2 Best of CGS BOG's & MARSH...
I can put them in my backlog if you pay enough razz Mr. Green
Me thinks.....NO!!!
RealDudes
SMS303
If you're not...
dude
gorgeous
lukas412
lukas412 wrote:
wow these looks so amazing. really wish i would have gotten in on these. nice work!
PM'd!
jenamu6
clarke68
You can if you want! I have extras. Send me a PM! thumbs up
Page 20 of 21
