1/4"- & XLR-to-banana for the Buchla 200e
Discussion and support for MOTU's Volta software.
Moderators: Kent, stretta
xpander
Post by xpander » Mon May 04, 2009 2:56 pm
here's another basic question- i need to make some cables that go from XLR-to-banana and 1/4"-to-banana for hooking my 828mk3 and 896mk1 up to the 200e for Volta-based control. what goes where?
:deadbanana:
1nput0utput
Post by 1nput0utput » Mon May 04, 2009 3:32 pm
Since the banana plug has no ground conductor, there's only one connection to make:
XLR pin 2 to banana
TRS tip to banana
http://motu-volta.blogspot.com/2009/03/ ... -200e.html
xpander
Post by xpander » Mon May 04, 2009 3:35 pm
thanks!
BugBrand
Knowledge of Bugs
Post by BugBrand » Mon May 04, 2009 3:47 pm
You'd have to make a common ground connection between the systems though (surely?!)
eg - just on the 1st jack you use -> take a connection from the jack sleeve to the Buchla's system ground point (which is.... well, I'm sure I don't know!)
1nput0utput
Post by 1nput0utput » Thu May 07, 2009 3:51 pm
BugBrand wrote:You'd have to make a common ground connection between the systems though (surely?!)
I think you're right, but someone more electrically knowledgeable than I should speak up.
xpander
Post by xpander » Thu May 07, 2009 3:56 pm
i assume that would be accomplished with the 1/4" audio cables.
Post by ignatius » Thu May 07, 2009 4:39 pm
1nput0utput wrote:Since the banana plug has no ground conductor, there's only one connection to make:
XLR pin 2 to banana
TRS tip to banana
but then you take the 'low' and tie it to the ground/sleeve. so pin two hot then 1 and 3 get tied together so both to ground..
at least i think that's how it goes? i know that's what you do when making TRS to TS or XLR to TS cables.
Return to “Volta”
