POWER w/o HP?
Gear, Suggestions and Discussion.
Moderators: Kent, flight, computer controlled
pacific202
POWER w/o HP?
Post by pacific202 » Sun Dec 25, 2011 3:06 pm
Is it possible to use the POWER barebones without the faceplate? I am constantly out of room and don't want to use up rack frontage.
computer controlled
Post by computer controlled » Sun Dec 25, 2011 9:25 pm
I'm going to say no, but don't quote me on that. I don't have one in my possession, but I'm guessing using any kind of powered module sans faceplate isn't the best idea.
:despair:
Stuff: SH-01A . TR-8S . MX-1 . D-20 . Waldorf MicroQ . Ensoniq ESQ-1 . Ensoniq EPS 16+ . Yamaha MODX6 . DX7 . TX802 . MPC Live . RE-303 . Avalon BassLine . Behringer Neutron . Behringer MS-101 . Behringer Pro-1 . Behringer K-2 . Behringer TD-3 . E-mu EmaxSE . E-mu Emax II . E-mu EMAX II rack . PCM 41 . BeatStep Pro . Keystep .
Rod Serling Fan Club
aquatic hitchhiker
Post by Rod Serling Fan Club » Sun Dec 25, 2011 9:34 pm
Yes, it's fine
pacific202
Post by pacific202 » Sun Dec 25, 2011 11:11 pm
Is it simply a matter of screwing the circuit board into the case? Are there any tips or hints from those that have done it?
computer controlled
Post by computer controlled » Sun Dec 25, 2011 11:16 pm
Ah, I see what you mean. Housing it inside the case would be fine, just keep it in a spot where it won't get touched by anything.
aquatic hitchhiker
Post by Rod Serling Fan Club » Mon Dec 26, 2011 12:40 am
Yes, I've done it. Goiks used it in a few cases I believe. I'm not sure what you want to know. It takes up space so expect to use shallow modules over it if it is in a shallow case. You could put the on/off switch elsewhere on the case or not use a switch and just unplug to power off.
Last edited by Rod Serling Fan Club on Mon Dec 26, 2011 10:35 am, edited 1 time in total.
aquatic hitchhiker
Post by Rod Serling Fan Club » Mon Dec 26, 2011 12:42 am
You have to do the wiring. You could always use uzeus for something that takes up less panel space if you aren't comfortable with electronic diy.
pacific202
Post by pacific202 » Mon Dec 26, 2011 12:44 am
Thanks, I'll talk to Matthew about it. I've been scoping out a new case from him and would like to support FoH.
flight
The Plague Bearer
Post by flight » Mon Dec 26, 2011 10:14 pm
Yes, you can definitely do this. This is what Goike uses on his wood boats. You can mount it to the inside of your case by using the front panel as a template for the holes for the switch, jack, and standoffs.
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
Return to “Flight of Harmony”
