System 700 filters
Discussion and support for the AMSynths range of analog synthesizer modules.
Moderators: Kent, emuarc
actionmusic2
System 700 filters
Post by actionmusic2 » Sat Jan 07, 2012 6:21 pm
coming here from a nod on the eurorack forum, and a search reveals there's lot's of roland influenced stuff from amsynths, hooray...
so looking for something system 700 like in terms of the multimode characteristics. anything in the range as yet that's close, or if not, something that's planned?
emuarc
Post by emuarc » Sun Jan 08, 2012 6:00 pm
I have replicated the Roland 703 SVF but so far it has not performed well enough to be released into production. However I will resolve the problems and have this filter into production later in 2012.
Rob Keeble
Owner & Designer
AMSynths
RobJB06
Post by RobJB06 » Mon Mar 04, 2013 7:08 am
Is the Roland SVF similiar to the JP6, really like the JP6 filter.
emuarc
Post by emuarc » Sat Mar 09, 2013 7:37 am
The JP6 VCF is essentially 2x 703 SVF's one after the other, with voltage controlled resonance and some refinements to improve the self oscillation. The 703 uses 2x CA3080 OTA chips, whilst the JP6 uses the IR3109 4xOTA chip. I have built a 703 and was not that impressed with the sound, the JP6 design sounds better. Hence the AM8060 module and no plans for the AM8703.
Rob Keeble
Owner & Designer
AMSynths
RobJB06
Post by RobJB06 » Mon Mar 11, 2013 11:30 am
Thats interesting. Ive heard people rave about the filters on the System 700, perhaps its just the low pass that people like.
I guess your JP8 filter probably resembles that Roland era low pass?
emuarc wrote:The JP6 VCF is essentially 2x 703 SVF's one after the other, with voltage controlled resonance and some refinements to improve the self oscillation. The 703 uses 2x CA3080 OTA chips, whilst the JP6 uses the IR3109 4xOTA chip. I have built a 703 and was not that impressed with the sound, the JP6 design sounds better. Hence the AM8060 module and no plans for the AM8703.
Return to “AMSynths”
