Aluminum Panel Guage???
nihilist
Post by nihilist » Thu Jan 26, 2012 6:48 pm
Hello,
what is the standard guage thickness for panels?
andrewF
Post by andrewF » Thu Jan 26, 2012 6:53 pm
2mm is nice, I think thats what the 'Best of CGS' panels are.
recently mine are 2.5mm
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Thu Jan 26, 2012 7:08 pm
The Doepfer mechanical spec page says the front panels are 2mm thick. http://www.doepfer.de/a100_man/a100m_e.htm We use the closest gauge that Metalphoto of Cincinnati offers which is more like 1.59mm (0.625").
Anything in that range will work.
-James
-James
daverj
Vintage Video Wiggler
Post by daverj » Thu Jan 26, 2012 10:38 pm
ersatzplanet wrote:The Doepfer mechanical spec page says the front panels are 2mm thick. http://www.doepfer.de/a100_man/a100m_e.htm We use the closest gauge that Metalphoto of Cincinnati offers which is more like 1.59mm (0.625").
-James
0.625" ?? That's a thick panel. :hihi: :hihi:
I've been doing mine with the .090" panels (2.28mm)
sduck
experimental use of gravity
Post by sduck » Thu Jan 26, 2012 11:08 pm
MOTM format panels are 3mm
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Fri Jan 27, 2012 12:37 am
-James
LOL - ha, that of course should have been 0.0625"
-James
-James
mikecameron
Thread Killer
Post by mikecameron » Fri Jan 27, 2012 11:19 am
on a related note, does anyone know what type of aluminum is best used? I bought some 6061 from metal supermarkets and it's just too damn hard to work with.
Dave Kendall
Set The Controls . . .
Post by Dave Kendall » Fri Jan 27, 2012 11:33 am
FWIW, if using 3.5mm Cliff 1384 jacks, according to the datasheet, the max recommended panel thickness is 2.5mm.
IMO this works well.
cheers,
Dave
Want to Buy: KURZWEIL KSP8
"Everything in moderation, including moderation"
Jarno
Post by Jarno » Fri Jan 27, 2012 12:51 pm
I used some 1mm thickness alu, because that's easy to get ovrrhere but that's too thin. 1.5mm seems to be the practical lower limit.
jumunius
Post by jumunius » Sun Jan 29, 2012 12:35 am
mikecameron wrote:on a related note, does anyone know what type of aluminum is best used? I bought some 6061 from metal supermarkets and it's just too damn hard to work with.
How so? That's what I use, .063" thickness (1.57mm) and it seems ok to me. But it's not like I tried different aluminums and picked my favorite. If there's something easier I'm all ears.
I do sometimes consider something a bit thicker though.
ndkent
Post by ndkent » Sun Jan 29, 2012 12:48 am
Modcan A seems to be about 3.25mm thick, so you might want to start with the format and then see what or if there is a standard
nd595
Post by nd595 » Wed Jan 09, 2013 3:30 pm
Yes it is - but in many ways it is easier to work on, especially that it does not catch your (expensive) milling bits and break them.
If you are unhappy and not afraid of posting to Spain I will buy that 6061 off you - please PM me.
BTG
Post by BTG » Mon Feb 18, 2013 1:05 pm
If I need a custom panel cut, are there services I can search for that would get me an aluminum panel for a specific HP width? I'd feel silly buying a bunch of metal working gear for a $15 front panel
daverj
Post by daverj » Mon Feb 18, 2013 1:14 pm
For small Euro panels it's cheapest to buy Doepfer pre-made blank panels. For wider panels it might be worth getting them done by Frontpanel Express. Their shipping costs are high, but if you skip the labeling they are fairly reasonable for blank panels with just the corner mounting holes, or even for complete panels with all the holes you need. A few years ago I had a series of blank panels made by them that just had the mounting holes and then I use them once in a while when I need to drill a new panel and mount something in it.
Getting aluminum cut by the online metal suppliers is going to give you metal that is approximate in size and you will need to file or grind the edges down to get it to the correct size.
Dave Kendall
Post by Dave Kendall » Mon Feb 18, 2013 1:19 pm
@ BTG - try a sheet metal works in the local town's industrial area.
It's worth getting a load of different widths cut whilst you're about it. Offering cash helps, and on a couple of occasions I got an even better deal by suggesting they used offcuts. The quality and accuracy was very good - much better than I could get at home. It's worth researching who they do work for by checking their advertising. I'm lucky - the local place does sub-contracted aerospace work, so it's top-notch work.
On two occasions, the equivalent of around $100 US got me enough panels to fill more than 8 - 10 x 3U racks. It works out cheaper per panel if you get a fair few made up.
Works for me! Image
cheers,
Dave
(BTW, actual dimensions of euro panels can be found on the Doepfer website.)
BTG
Post by BTG » Mon Feb 18, 2013 2:24 pm
I'll give FPE a look then, much easier than trying to sort this on my own, the only downside being that if I screw up the measurements it's expensive. Thanks!
