freaky Hex Zone issue
Author freaky Hex Zone issue
Kwote
the LCD screen went blank. i panicked and was all set to email John but it's suddenly back to normal.
i was inches away from being a SAAAD PAAAANDAAAAAA.
nathankirchner
If the unit crashes, freezes, hangs, etc. the LCD is not cleared - it will either hold the last thing on the display or, if it has a chance, will throw up an error code.
If your display went blank then that means you lost power. maybe you have a loose cable or there was a brown out?
If it happens again, let us know.
Gloworm
Mine went blank and stayed that way. John sent me a new beatle and after I installed the new one all was up and running again.
Kwote
no loose cables or brownouts. all my other modules were rock solid. only lasted for a few minutes. i'll keep you posted if it happens again.
Kwote
good to know. i'll keep that in mind if the time comes.
