KOMA KOMMANDER update
MUFF WIGGLER Forum Index -> KOMA Elektronik Goto page Previous  1, 2, 3, 4  Next [all]
Author KOMA KOMMANDER update
Silent Strike
Monobass
I trust ad infinitum cables fit ok?
dan_k
Nope, unfortunately not.
I've got Doepfer, Ad infinitum and Erthenvar and only the Doepfer cables are slim enough to fit if you want to use jacks next to each other.
Pick yourself up some Doepfer cables and leave them plugged into the Kommander full time. You're going to want to have it ready anyway since it's so awesome! Guinness ftw!
Monobass
Oh ok. Wish I knew that before I placed my schneiders order... Anyone want to swap 4 doepfer cables for 4 ad infinitum cables?...
artisokka
Monobass wrote:
Oh ok. Wish I knew that before I placed my schneiders order... Anyone want to sell me 4 doepfer cables?
...4 Doepfers for me too, thanks.
drip.feed
Thomann sells Doeofer cables, all different lengths. Search for a-100c.
Here are the 3 longest ones:
http://www.thomann.de/gb/doepfer_a100c80_patchkabel.htm
http://www.thomann.de/gb/doepfer_a100c120_patchkabel.htm
http://www.thomann.de/gb/doepfer_a_100c200.htm
Monobass
could someone take a picture of the business end of the Kommander please?
edit - found one - doesn't like being embedded though.
http://de-bug.de/musiktechnik/archives/6137.html/koma3
matttech
Emis in Bristol sells Doepfer cables too.
dan_k
Here's a close up, with a 9V battery for scale.
It is smaller than I expected. Not that that's a a bad thing but was just surprised when it arrived.
Monobass
all timbral articulation is Kommander. Check the O'Tool for a CV plots.
my left hand filter cutoff (SEM20), right hand X morph (e350)
I also have the filter cutoff CV going through some MATHS slew, mainly on the fall time.
LOVE love that this thing is sensitive enough to do guitar vibrato scale modulation! shaky hand LFOs for the win.
Monobass
can anyone tell me what the max diameter is of the plastic on doepfer cables?
sundog
approx 7mm?
Monobass
I turned my Ad Infinitums into Doepfer cables with the simple application of KNIFE
Monobass
so it seems quite easy for the gates to get stuck on, any tips?
one of mine is releasing the gate too low, the other too high.. I can adjust that with the trimmers... but they both seem to get stuck on quite easily.
Monobass
if anyone is interested, I just built a really simple passive circuit to do gate to trigger conversions.. works fine with Kommander, 8v gate in is giving 4v trigger out and happily triggering 99% of my modules.
https://www.muffwiggler.com/forum/viewtopic.php?p=893749#893749
jeannot
Haven't used my gates for anything yet. But I love how accurate the CV is with the active IR sensor, super-precise. Always loved those sensors, active IRs and Max/MSP Jitter, MY ASS IS BLEEDING
osterchrisi
Hey, can you explain what you mean exactly with 'get stuck'? The gates are realized with a Schmitt Trigger, so they have a small 'window' where they flip to and stay high. The threshold for flipping high is a tiny bit lower than the threshold where they flip low again to prevent mulitple flips / multiple gate highs if you drank too much coffee hihi So it could be that you simply have to move your hand a bit farer away to get it low again.
Monobass
Yeah sure - simply that I can remove both hands and step away from the Kommander and the gates are sometimes staying high.
DanielW
A little "oil drum" patch I made:
[s]http://soundcloud.com/neizvestija/kommander-on-oil-drums[/s]
Kommander controls the Make Noise Optomix VCA, with a gate going into STRIKE and cv in the other two black CV inputs.
Sounds are from self oscillating cross-patched Plague Bearers into WMD Micro Hadron Collider VCF. Routed through Sherman Filterbank and WMD Acoustic Trauma. FX by Eventide Pitchfactor, Timefactor and Space.
DanielW
BTW, two Doepfer and two Ad Infinitum cables fit nicely side by side on the Kommander.
DanielW
OK, one more with the same basic setup, plus Machinedrum. A bit more melodic this time:
[s]http://soundcloud.com/neizvestija/in-kommand[/s]
de_raaf
orded one friday at escape from noise, looking forward :-)
Vcoadsr
Just pre-ordered a Kommander from Koma website.
Anyone know when this 2nd batch will be available?
tektoktiktak
Hey ya'll!
In 3 weeks a whole new run of KOMMANDERS will be leaving our workspace. The last run was sold out in 1,5 weeks, so make sure you reserve your unit before its too late!
This is the link where you can pre-order:
http://www.koma-elektronik.com/products/kommander/ applause
nrdvrgr
...any news on bananaoptions (and ground jack). One can at least hope.
Page 3 of 4
