Marienberg modular system
MUFF WIGGLER Forum Index -> 5U Format Modules Goto page 1, 2, 3, 4, 5  Next [all]
Author Marienberg modular system
lucid
Hi, this seems to be another European 5U producer, but I cant find anything on web just this one :
http://www.1a-shops.eu/cgi-bin/shopserver/shops/s017916/index.cgi?akti on=um&ps=248286&subid=248286
so far it looks to be only in German language, which is also not the best for me
Is there anybody who know more about it? seriously, i just don't get it
There is also mentioned that 2012 there should be another modules.
Please if you know something more share info, links, experience, etc...
woah
synthnut
...Hmm looks interesting!
I like the look of the MIDI-CV unit, not a bad price either. Then look at the multiples, 143 Euros, that's an odd pricing structure!
Some of the panels seem to be folded and others flat too...?
One to watch methinks!
TTFN,
Ben
www.resynthesis.co.uk
www.bigbluewave.co.uk
e-grad
Even if it sounds odd: You get what you pay for.
At least that's what I guess: You pay for the pleasure that the owners of Marienberg have assembled the Mult themselves. Also I'm rather sure that any module is rather one of kind than mass production. So economies of scale don't apply here. Coloring, lettering of the panel and parts used are suppossed to be high quality.
AFAIK it is a project of two brothers who do not persue any commercial success. Rather they enjoy to develop and to share a sophisticated modular system for their own pleasure.
However, I've no idea whether their modules come up to their own expectations. There are hardly any Marienberg modules floating around for the time being.
Putte
Marienberg, nice name, but the prices are way too high. There are two prices, the lower for non EC-members?
The multimode filter looks interresting, though. Looks a bit Moogish, and the three sections are voltage controllable from other sources. Well, if I somehow just stumble on 348 euros on the street, there might be a chance.
I´m guessing this is a fairly new company. I´m sure stranslation into english will follow, as well as more pictures of the modules and larger systems.
But I have to say it´s great that there´s another company producing all the bread and butter modules.
Putte
Also, has anyone seen what kind of connectors these modules have? I mean, how compatible are they to other modules?
e-grad
One price is incl. VAT the other without VAT. This is of interest for non EU-citizens (as suggest by you) and for professionals.
I've seen the first couple of their modules at Schneider's about one or two years ago.
komyta
I just found this picture somewhere on a german forum.
No standard MU power connector. sad banana
suitandtieguy
well it's nice to know they feel absolute contempt for their potential market.
not putting a Synthesizers.com power header on your Moog-format modules is ridiculous in 2012.
MOS-LAB i understand, because he's using 12V, but i still think he should have got on board.
bwhittington
Man, check out that EG. Gate outputs for each stage? Retrig. Decay to Release switch . . . would that go to the release stage with no sustain length? (EDIT: Stumbling through an online translation, it appears the Decay to Release switch is just an AR to AD thing, not some two-stage release I had been fantasizing. There appear to be two function-oriented jumpers on the pcb as well.) Definitely fascinated with that one. The stage outputs look really fun.
- analogen Spannungen ( +/-15V ) sind, unabhängig von der Last, bis aufs Millivolt genau und stabil
- digitalen Spannungen ( +3.3V und +5V )
The power header is that big of a deal, but they apparently also use 3.3v for some modules. That could be a bit of a trick. Looks like the EG might just use 15v, and that's the only one of the current line up I'm particularly interested in.
synthnut
Hi all...
There's possibly some logic to not having a standard PSU connector if your PSU is non-standard then!?
I suppose they could supply an adaptor cable for each module though to whatever system you happen to use, then everyone is happy...?
I still can't get over how a mult is E143.00, an attenuator is E234.00 while a quad MIDI to CV is just E260.00 It seems to be the opposite of you get what you pay for personally. I know the panel is usually the single most expensive "component" after labour, but 3 pots aren't one hundred Euros more expensive than eight jacks??? seriously, i just don't get it
Interestingly the attenuator is called "voltage controlled attenuator" but I can't see any reference to this in the description or panel.
Obviously a manufacturer can charge whatever price they feel like for a product. Maybe they don't like making these and would rather concentrate on the interesting modules perhaps! hmmm.....
The VC-ADSR is certainly comprehensive to say the least! eek!
I think there's going to be quite a bit of new MU comming over the horizon... love
TTFN,
Ben
bwhittington
Apparently we're really slacking off around here. There was an announcement of the filter module on Schneiders in July 2010:
http://www.schneidersladen.de/en/marienberg-devices-vc-multimode-filte r-2
bwhittington
double post
e-grad
So what do you suggest? They roll the dice three times to come up with a price?
I'd once enquired about a run of professionally made 5U panels. The quote brought the whole project to an end.
I doubt that Marienberg can come up with with a price for the modules that you'll consider a fair epuivalent for your money. You seem to compare their prices to other makes but you have to approach the price from the costs of production. Keep in mind .com for example will pay way less for one of their panels then Marienberg. The same goes for any other component.
I'm not in the marktet for their products for various reasons however I think it's a passionate project which I hold in high esteem.
lucid
OK, maybe I should do it first, but at the end I found some more info - again only in german - just right here.
http://synthesizerarchiv.de/
you need to click on MODULAR on the left side panel to read more about them and scroll down to links to specific modules...
bwhittington
Nice find! There are bunch of proposed modules on that page, including a wavetable oscillator and eight phase sine oscillator, that make the line more interesting. Fun stuff!
http://synthesizerarchiv.de/modular/vc_wto/wavetable_test_1.mp3
http://synthesizerarchiv.de/modular/vc_wto/wavetable_test_2.mp3
galaktyk
Yes good news for Europeans. If I didn't gone modcan I would build an Marienberg maybe. I read the article in synth magazine about that System sounds good what they make. But the panel style i like more from Macbeth, the compact size on the backside is a big + for me. Hope they'll bring out some nice filters in future. Seems I've to build an another black system, too.
God please let money rain....
synthnut
Hi,
I don''t quite understand your remark here:
My comments just relate to the disproportionate costs of some very basic passive peripheral designs versus a highly complex one which does more "high value duties"
How a 2MU design, stuffed with electronics, displays and connectors costs just 26 Euros more than a 1MU passive (?) attenuator module.
Don't get me wrong, I think it's amazing for people to build systems out of a passion and have a no compromise approach, but there should be a diferential in price between these, either based on the diferent costs, or values of the products. The investment in time in developing a complex circuit is very large one way or another, but a mult or attenuator doesn't require hours on end of R&D or debugging etc.
Frankly is does seem as if they used a dice to decide the prices here, you only have to compare the costs of those modules with anyone elses versions to see that something is out of kilter. hmmm.....
It is however entirely their prerogative to charge whatever prices they wish, or maybe it's a typo?!
I'm very interested in the wavetable oscillator, as someone who had four Digisound VCDO's and owns a PPG 2.3 that's a real teaser! (especially if it's the same price as the MIDI-CV!!! hyper
We definitely have been slacking here to only have noticed this maker so late in the game.
This is certainly a renaissance with bells and whistles on in the modular world. More MU is good for you, that's my motto...
TTFN,
Ben
e-grad
Just to make sure: My posting wasn't ment to be rude. I just want to point out that the price is not arbitrary but comes from the cost side.
I'm rather sure it's the face plate drives the price up. I've read somewhere that they choose a high quality and costly method to have it both immaculate and make the lettering long lasting. Furthermore, I'm rather sure you won't pay for the development of the circuit design.
Thus I guess it's the front panel plus a tiny bit of the manual labour and some overhead costs that brings even the most simple passive module in a price range which is prohibitive for most people. I think at Marienberg they are well aware that one of their multiples will be sold only to a handfull of devotees who own a complete Marienberg system.
Dr. Sketch-n-Etch
In my experience, prices are generally fixed by distributors based on the perception of value relative to the marketplace with respect to features, size, reputation of the manufacturer, etc. This means that you make a ton of money on stuff like mults, attenuators and CV manglers, and less money on stuff like VCOs and filters. Cost ultimately has less to do with it than one might think.
emdot_ambient
I actually agree with that. Take a look at Moon Modular. Their multiple is far, far, far less expensive than their higher density modules. And their prices aren't exactly bargain basement price busters. (don't get me wrong, I think Moon prices their stuff fairly based on their functionality and knowing they're a small company.)
If they keep their multiple that price they won't be able to sell any of them, unless it's a buffered multi, of course.
e-grad
Good point yet Marienberg has no "real" distributor. How many Wigglers have done business with SynMag? One? None?
Whether Analgoue Heaven nor Schneider list Marienberg as a make they distribute.
misa
German Synthesizer Magazin has an article on them:
http://www.synmag.de/
They were also at Musikmesse and their modules sound very nice. The guy I spoke to (Daniel) was also very nice and interested to get to know more potential users (and customers). They seem to have created something where they feel the clarity of sound justifies the price.
I told him about muffwiggler and it seems he hadn't heard of it yet. I guess he will pop up here soon then we can grill him about his thoughts and plans..!
bwhittington
I'm not seeing the article online. Is there any contact information for them in it? Or do you (or anyone) happen to have their email address? I want to try out one of the EG's but am having a bit of trouble navigating the German pages. As far as I can tell the shopping cart shown online doesn't ship to the US, plus I'd like to inquire about lead times and all the details before payment anyway.
galaktyk
their circuits are optimized for best quality without disturbances from electricity. The switches and knobs are mounted directly to the pcbs to avoid electricity influences so they say their modules can create unique clear sounds. As well they want to create modules with the most flexibility and without cost limit of highend parts.
I think that's a little bit German Modcan if I could say that carafully. The price is for me fine, so if I order modcan from Canada their modules are more expensive for me with duty etc.
e-grad
To my best knowledge the Syn.Mag. is not an online but print magazin.
AFAIK the Marienberg guys run the synthesizerarchiv. Follow the link below and right down at the left there's their email.
http://www.synthesizerarchiv.de/
Here's their list of modules again scroll down.
http://www.synthesizerarchiv.de/html/modular.html
Any info (lot's of it) is in German.
Page 1 of 5
