choices joystick potentiometers
Gear, Suggestions and Discussion.
Moderators: Kent, computer controlled, flight
snufkin
Post by snufkin » Tue Mar 27, 2012 11:37 am
Hi guys I have a question
I recently got a 4 pot joystick at a surplus place and was thinking I might be able to build up two barebones choices kits to build a dual parallel joystick module for myself, basically everything twice as I have one more sets of pots moving in the same way
the pots are measuring around 18k on this thing is there any chance components can be swapped out on the bare bones kit as I am aware it's designed for 100k pots
thanks
Chris
WTB: any Digisound80 / Digisound 80 faceplates/pcbs/kits.
snufkin
Post by snufkin » Tue Apr 17, 2012 4:59 pm
bump
snufkin
Post by snufkin » Wed May 02, 2012 6:20 am
one last try, any input on this ????
Tombola
Post by Tombola » Wed May 02, 2012 6:31 am
I have never seen the schematic for the Choices joystick, but I would *imagine* the pots will be set up as voltage dividers.
If so, the change from 100k to 18k shouldn't make any difference to the circuit at all, assuming they're both linear.
Ken Stone's joystick module page has some other suggestions: http://www.cgs.synth.net/modules/joystick.html
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Wed May 02, 2012 9:59 am
You should be able to use any pot in the voltage creating peer - the choices also processes signals directly and that side of the circuit might be more finicky. The only advantage of using this dual action is if you want to have different ranges on the same axis or inverted action but I would imagine that an inverter or a scaler coddle would be cheaper (or as cheap) than two joystick circuits - and a lot more flexible.
-James
Return to “Flight of Harmony”
