plague bearer gain knob, doing... nothing?
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
nooneimportant
Post by nooneimportant » Sun Apr 01, 2012 2:09 pm
How subtle is the gain knob? No matter how I patch the plague bearer, I can't hear it doing anything. Maybe I'm confused about its function? :help:
infradead
leader of the secret trombones
Post by infradead » Sun Apr 01, 2012 2:15 pm
turn high all the way up.
turn gain all the way.
don't forget gain is counterclockwise!!
listen to shit get real.
also what ver of the PB do you have?
forget everything you know about sound, then turn the synth on. You can thank me later - slow_riot
cases: doepfer 6u and monster base
Tacoma Noise Rodeo
nooneimportant
Post by nooneimportant » Sun Apr 01, 2012 2:31 pm
Yeah that doesn't really do anything... I can post a video if that'd help, but really I hear no change.
I've got version 4, it's less than a week out of the box.
EDIT: ok i'm getting a bit of a response out of it, perhaps I'm just not giving myself enough time to learn this module? It's still pretty darn subtle, but I'm also not feeding it anything terribly complicated.
infradead
Post by infradead » Sun Apr 01, 2012 3:16 pm
hmm that's weird.
on mine running audio through it turning the high all the way and turning the gain all the up is really noticable..
where do you have the input level at? i normally keep mine at 12 o'clock
Tacoma Noise Rodeo
nooneimportant
Post by nooneimportant » Sun Apr 01, 2012 3:33 pm
I sweep it all over the place...
You know what I'm just going to plug an iPod into it and see what happens.
obscurerobot
Turing Tested
Post by obscurerobot » Sun Apr 01, 2012 8:40 pm
nooneimportant wrote:I sweep it all over the place...
That's easy, it will eat your iPod's soul.
infradead
Post by infradead » Sun Apr 01, 2012 11:19 pm
ok did some tests.
first is a my uflo playing some rene ditty that i'm so tried of listening to now :omg:
after the pause is my plague bearer ver4 with all knobs at 12 o'clock or close enough.
after the next pause you hear the gain being cv'd by my vulcan modulator's max out.
the gain input is only looking for positive voltages. good to know
Tacoma Noise Rodeo
infradead
Post by infradead » Sun Apr 01, 2012 11:46 pm
infradead wrote:turn high all the way up.
wait is it?
fuck!?!?!??!?!?!?!?!?!!??!
PB is eating my minnnnnddddddddddddd
Tacoma Noise Rodeo
obscurerobot
Turing Tested
Post by obscurerobot » Mon Apr 02, 2012 12:16 am
infradead wrote:wait is it?
Are you sure? My PB only likes to dine on souls. All of my shoes are ruined now :(
computer controlled
Post by computer controlled » Mon Apr 02, 2012 3:02 am
What do you have the Limiter switch set to?
Stuff: SH-01A . TR-8S . MX-1 . D-20 . Waldorf MicroQ - Waldorf Microwave II . Ensoniq EPS 16+ . Yamaha MODX6 . MPC Live . Avalon BassLine . Behringer Neutron . Behringer MS-101 . Behringer Pro-1 . Behringer K-2 . Behringer TD-3 . Microvolt 3900 . BeatStep Pro . Keystep .
Nesto
Post by Nesto » Mon Apr 02, 2012 5:02 pm
I am also having the same issue with a plague bearer two weeks out of the box- And this is the second one! (i exchanged the first because the "high" knob was having the same problem...)
When I send CV to the gain input, I hear what I assume is the full range, but when I turn the knob, I can hear almost no difference, and what little
I can perceive I have to listen awfully hard for.
The weirdest part is, that I could swear it was working fine until yesterday.
Should the knob have the same range of effect as the CV input??
Nesto
Post by Nesto » Mon Apr 02, 2012 5:23 pm
I bet I am just being paranoid cause the first one was busted.
It is a mysterious module! :rastanana: and, yeah...
Nesto
Post by Nesto » Mon Apr 02, 2012 5:37 pm
Ok, sorry for all these posts.
I finally read the manual and found this:
"Making Noise
The PB filter can also act as a noise generator, and quite a variable
one at that. To do so, just turn the input all the way down (CCW), turn
the gain up a bit, and then adjust the High and Low controls to get the
desired tone of noise. You can get some interesting percussion sounds by
applying an impulse or saw wave to the High CV input, or some nice wind/
whooshing sounds with a slow sweep. Daisy-chaining (series-connecting) a
couple filters makes some nicely creepy ambient effects.
Caveat: The noise feature is very quiet! I'm talking millivolts here. It
works, trust me, that is the first and last function I test before shipping. If you
can't hear any noise, crank up your output amplifier. If you still can't hear it,
use a preamp as well. It is worth it!"
and cranking my vca/mixer, I can hear exactly what is described, and the gain knob seems to work fine with these settings.
User ineptitude. Case closed.
Off to explore! :nana:
goab
Post by goab » Thu Apr 05, 2012 12:14 am
I usually find that running the input signal too hot will make the PB (r4 in my case) "less responsive", sometimes leading to the knobs "doing nothing". Try to back down the signal (with the attenuator switch and input trim) to where it's just audible, then turn gain. 10-11 o'clock usually sounds sweet and gnarly.
Nesto
Post by Nesto » Thu Apr 05, 2012 5:14 pm
Yeah, I was mainly confused because whatever the settings, cv'ing
the gain knob gives me a much wider range.
for instance, putting a square wave into the gain cv goes from
Gnarly to dead-silent, whereas no matter what the settings, the gain knob
turned manually never results in silence.
should the gain knob fully ccw result in silence?
whatever the case, it sounds great!
mhtones
Dreams in CV
Post by mhtones » Fri Apr 06, 2012 8:57 pm
I generally find that I get the most out of my rev 3.3 PB by having the input very attenuated, like at 9oclock or less. At that setting, the rest of the knobs have a much more dramatic effect.
Return to “Flight of Harmony”
